April 24, 2015, 06:07 |
Conditions in which yPlus does not matter
Rubén
Rep Power: 11 |
Hi FOAMers!
I am running a turbulence case of an incompressible flow around a rotating disc. The yPlusRAS utility gives me this values: Code:
Patch 5 named cuerpo y+ : min: 0.0062716 max: 42.1937 average: 3.33432 Patch 6 named bordes y+ : min: 0.0042175 max: 15.3098 average: 2.02145 My question is: Does a combination of turbulence model+boundary conditions at the walls/wall function exist in which the yPlus value doesn't matter? As I have read, omegaWallfunction can change from Low-Re to High-Re, but in this thread is not completely clear: http://www.cfd-online.com/Forums/ope...omega-sst.html The paper of Menter agrees. So, I am a little bit worried, because I don't know what to do. In this paper http://www.tfd.chalmers.se/~hani/kur...DES-Report.pdf, the only wall function they use is the omegaWallfunction, and they don't talk about yPlus, so I don't know if it does matter.... Can you help me? I would like to finish my thesis, but I am confused.. Thank you very much in advance !!! |
April 24, 2015, 06:19 |
Rubén
Rep Power: 11 |
My current boundary conditions are:
kinetic energy: Code:
GNU nano 2.2.6 Archivo: 0.org/k /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $turbulentKE; boundaryField { inlet { type fixedValue; value uniform $turbulentKE; } outlet { type zeroGradient; } cuerpo { type kqRWallFunction; value $turbulentKE; } bordes { type kqRWallFunction; value $turbulentKE; } #include "include/frontBackUpperPatches" } // ************************************************************************* // Code:
GNU nano 2.2.6 Archivo: omega /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 0 -1 0 0 0 0]; internalField uniform $turbulentOmega; boundaryField { inlet { type fixedValue; value uniform $turbulentOmega; } outlet { type zeroGradient; } cuerpo { type omegaWallFunction; value uniform $turbulentOmega; } bordes { type omegaWallFunction; value uniform $turbulentOmega; } #include "include/frontBackUpperPatches" } // ************************************************************************* // Code:
GNU nano 2.2.6 Archivo: nut /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } cuerpo { type nutkWallFunction; value uniform 0; } bordes { type nutkWallFunction; value uniform 0; } #include "include/frontBackUpperPatches" } // ************************************************************************* // frontBackUpperPatches: Code:
GNU nano 2.2.6 Archivo: frontBackUpperPatches /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ top { type slip; } bottom { type slip; } frontandback { type slip; } // ************************************************************************* // initialconditions: Code:
GNU nano 2.2.6 Archivo: initialConditions /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ //Para un Re= 270000 flowVelocity (15 0 0); //6 revoluciones por segundo, de Flight Dynamics Measurements on an Instrumented Frisbee //Ralph D Lorenz //Lunar and Planetary Laboratory, //University of Arizona omegadisk 37.7; pressure 0; //turbulentKE=(3/2)*(UI)˛ //Para U=15; I=0.005; //turbulentKE=k=0.02434614 turbulentKE 0.0084375; //http://www.cfd-online.com/Tools/turbulence.php //http://www.esi-cfd.com/faq/index.php?action=artikel&cat=4&id=156&artlang=en turbulentOmega 1125; #inputMode merge // ************************************************************************* // |
April 24, 2015, 08:23 |
#3 | |
Roman Thiele
Rep Power: 20 |
There are no RANS turbulence models which depend on y+ on one way other another. However, you could try to use the approach described in post 3 of the thread that you mentioned http://www.cfd-online.com/Forums/ope...tml#post306339 with the nutUSpaldingWallFunction for nut.
~roman |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 02:13 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
hexagonal boundary conditions | s_h | Main CFD Forum | 0 | August 9, 2009 23:15 |
Modeling new matter! | Sunil Hadap | Main CFD Forum | 2 | February 23, 2000 18:06 |
