Potential bug in turbulentTemperatureCoupledBaffleMixed
Old   April 30, 2015, 23:38
Exclamation Potential bug in turbulentTemperatureCoupledBaffleMixed
N/A
kamakura117 is on a distinguished road
I am using the turbulentTemperatureCoupledBaffleMixed boundary condition with chtMultiRegionFoam and OpenFOAM v 2.3.1. I am running the solution until a steady-state condition is reached to verify with steady-state solutions.
I have two blocks in contact; one block contains a constant volumetric heat generation (first image, block aligned with x=0 has a source of 1e6 w/m^3). In the first case there is no contact resistance and the results match with analytical calculations (second image). At the x = 2*L (with L being the length of one block), I have a constant wall temperature. The other boundaries effectively make this a 1D problem.
However, now I apply a contact resistance:
box_1_to_box_2
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           uniform 310.0;
        Tnbr            T;
        kappa           solidThermo;
        kappaName       none;
        thicknessLayers (1e-5);
        kappaLayers     (1e-2);
Such that the resulting temperature drop, with my source, should be 20 K. When I run the case, I get this temperature drop, roughly. However, the peak temperature of the system is significantly higher than it should be. MOREOVER, when I refine the mesh, the temperature distribution just climbs(third image). In this image, two of the many meshes are shown, a tet mesh and hex mesh. The high temperature distribution is for the tet mesh. The "peak" temperature should be 686 K.
I am just starting to diagnose why this is happening, but I won't be able to get to it in the near term. I just wanted to put this out there.
Last edited by kamakura117; April 30, 2015 at 23:42. Reason: Added version number.
kamakura117 is offline   Reply With Quote
Old   April 30, 2015, 23:49
N/A
I just submitted a bug report:
http://www.openfoam.org/mantisbt/view.php?id=1682
Bug in Workbench CFX Pierre1 CFX 6 August 2, 2017 00:18
Problem modelling potential equations with addtional variables pmtgt CFX 4 October 3, 2013 08:20
How to calculate electrical potential with UDS? seagullor FLUENT 2 July 5, 2012 02:04
Potential Flow Swapnil CFX 5 February 26, 2003 07:33
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
