combining mapped & codedFixedValue for inlet?
Like Tree1Likes
  • 1 Post By canopus
Old   May 24, 2015, 06:39
Default combining mapped & codedFixedValue for inlet?
SM
canopus is on a distinguished road
Hello
Is it possible to combine the mapped inlet with a codedFixedValue in OF?
The purpose is that I want to put an oscillating flow and map it back at downstream
so that I can get a developed profile without using a long channel segment?
Thanks
SM
canopus is offline   Reply With Quote
Old   May 25, 2015, 05:53
SM
Just to further clarify the problem
I want to do LES of an oscillating flow i.e. a sinusoidal flow without a mean component in a channel.
In order to have a fully developed flow at lower mesh count without using a long channel I want to map it back at a location from downstream or recycle from outlet.
For sinusoidal profile I used codedFixedValue in RANS.
For mapping I can use something like mappedpatch as in PitzDailyMapped tutorial.
Is it possible to combine the mapped inlet with codedFixedValue in some way?
Any other suggestions which reduce computational effort are also welcome .
ucceyrekkokorec likes this.
Old   February 23, 2022, 09:14
mfr
ucceyrekkokorec is on a distinguished road
Have you found a solution? I'm working on a similar project
ucceyrekkokorec is offline   Reply With Quote
Why are pointVectorFields not mapped using mapFields? maxof OpenFOAM Running, Solving & CFD 6 June 19, 2023 11:50
Boundary Condition For Mapped Fields in OpenFOAM Alhasan OpenFOAM Running, Solving & CFD 32 January 11, 2014 17:51
Using codedFixedvalue to apply totalPressure Boundary Condition cdm OpenFOAM Running, Solving & CFD 2 June 22, 2013 14:10
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 11:58
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 11:56
