May 28, 2015, 11:49 |
Odd mapFields issue/question
Rep Power: 15 |
Hello, I'm trying to use mapFields to map a solution from the center of a domain to an inlet. I've run a RANS case, copied the data to a new folder, moved the points in the mesh (to align the ~center of the mesh with my new inlet boundary), and then ran mapFields to map the results. This works OK, I do not get any errors, and my data has been mapped and the variable files have been altered (U, k, omega, etc...).
However, when I went to check that everything was mapped correctly, I found an odd problem (which I am not sure why it happened, if it is somehow intended or is related to an error I unwittingly made). Looking at the velocity profile from the original plane (where the data is mapped from) and comparing it to the plane it was mapped to, there is a difference. (See attached image of U+ vs y+) Also, the mesh is exactly the same, so there should be no interpolation issues that I can think of. The reason for this difference is apparent when I look at the data itself, the velocity profile data maps correctly for every point except the one closest to the wall! The velocity normal from the wall appears as follows: Code:
Profile pre-MapFields 0.022711 0.052292 0.090609 0.13256 and so on... Profile post-MapFields 0.017012 0.052291 0.090607 0.132557 and so on... Why is this occurring? Am I doing something incorrectly? Is this somehow intended? Thank you! |
Issues with mapFields | BlackBoatNavArch | OpenFOAM Pre-Processing | 38 | May 28, 2021 16:29 |
Strange random behaviour of mapFields | blaise | OpenFOAM Pre-Processing | 0 | November 3, 2014 09:37 |
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 | shuoxue | OpenFOAM Pre-Processing | 1 | April 28, 2014 05:59 |
Zero Pressure with mapFields | ignacio | OpenFOAM Running, Solving & CFD | 0 | May 24, 2013 09:43 |
transientSimpleDyMFoam, mapFields and decomposePar | pad | OpenFOAM Running, Solving & CFD | 0 | December 3, 2010 05:22 |
