Maximum number of iterations exceeded while doing a rotor 37 simulation
2 Attachment(s)
I am doing a rotor 37 simulation of a single blade passage with periodic BC using openfoam 2.3.0.I has added SRFModels to sonicFoam,and I get the SRFsonicFoam,it is Compiled successfully.But I'm getting this error(I also has running it with rhoCentralFoam and also using foam-extned 3.1,but the same problem cames):
--> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting Attach Files are my solver,0 files.Can anybody help me.... |
I"m experiencing the same error. Have you been able to fix the problem? Franco |
Hi,Franco
I haven't solved the problem.And I change to density based solvers,which works fine. |
Thank you very much Thomas. May I ask you which solver are you using now? I'm using chtMultiRegioSimpleFoam.
I'm using transonicMRFDyMFoam in of-extend1.6.It's density based solver ofsimulating the rotating machinery . I don't think it can be sed for you.
I agreee with you. However, thanks again :)
