Continuity error using buoyantBoussinesqSimpleFoam |
June 20, 2015, 12:32 |
Andreas
Rep Power: 10 |
Hello all,
I'm new to OpenFOAM and I have run into a problem using the buoyantBoussinesqSimpleFoam solver. This is the error message that I receive: --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 0.00108558 Specified mass inflow : 0.08 Specified mass outflow : 0 Adjustable mass outflow : 2.95803e-23 I have checked my BC's and they seem fine (U: fixedValue at inlet and zeroGradient at outlet, p: zeroGradient at inlet and fixedValue at outlet). I have also tried initialising with potentialFoam but then I get following error message: --> FOAM FATAL IO ERROR: keyword potentialFlow is undefined in dictionary But I have already defined the potentialFlow in the fvSolution file... Thankful for help! |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
