[Sponsors] | |||||
buoyantBoussinesqPimpleFoam solution diverge at reference pressure cell |
Sumit Singh
Rep Power: 13 ![]() |
I am using userbuoyantBoussinesqPimpleFoam in OF 2.3.1. to solve natural convection on heated cylinder. BCS used are Inlet: T fixedValue U zeroGradient P fixedFluxPressure P_rgh calculated Cylinder T fixedValue U fixedValue P fixedFluxPressure P_rgh calculated side Walls: T zerogradient U slip P fixedFluxPressure P_rgh calculated outlet: T zeroGradient U zerogradient P fixedFluxPressure P_rgh calculated When running the simulation with these BSCs, solution get diverge at reference pressure cell. I also tried by changing outlet P_rgh BSC to fixedValue, then solution at outlet boundary is weird. |
did you manage to find a solution? I am facing the same problem for days and I fear that I am going crazy. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Operating pressure and Reference pressure Location-1 | kamal_g65 | FLUENT | 0 | September 16, 2010 21:52 |
| Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
| Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
| Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
| Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
