initially diverging temp in one cell using convMeltFoam
Old   July 10, 2015, 11:59
Default initially diverging temp in one cell using convMeltFoam
kh
KHoy is on a distinguished road
Hello all,
I am using the convMeltFoam solver posted by Fabian Rösler with OF 2.4.0. After changing BC for p_rgh to zeroGradient and replacing in pEqn.H
/*phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rAU, U, phi);
with
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi);
the code compiled and ran but has a hard time converging in the very beginning second of the computation independent on whether fixed or variable time stepping is applied.
The problem appears at the left bottom corner cell of the domain, where temp BC are zeroGradiant from below and imposed T > T_melt from left for t>0 with initial T < T_melt everywhere. Also with variable time stepping, the time steps become very small to keep Courant # in bounds, but the velocities are nowhere really large to warrant those small dt.
I am fairly new to OF so I would appreciate good advice.
Attached is a screen shot after 0.4 s when the cell is way out of bounds. This error decreases later in the computation to non-existent.
KHoy is offline   Reply With Quote
Cell Reynolds Number laliong Main CFD Forum 12 September 17, 2019 04:18
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
Partition: cell count = 0 metmet FLUENT 1 August 31, 2014 20:41
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
pls help : udf & cell temp. A. H. Jaberi FLUENT 0 December 16, 2004 06:33
