Error while running pimpleDyMFoam
Hello everyone, I'm new at working with OpenFoam and an error appear while running
mpirun -np 8 pimpleDyMFoam -parallel I can't figure a way to solve it. The error is: --> FOAM FATAL IO ERROR: [4] keyword cellMotionU is undefined in dictionary "IOstream.solvers" [4] [4] file: IOstream.solvers from line 0 to line 0. [4] [4] From function dictionary::subDict(const word& keyword) const [4] in file db/dictionary/dictionary.C at line 608. I'm grateful for any help you can provide me. Thanks. Daniela |
Do you have something like Code:
First of all thank you so much for answering me!
My fvsolution is the following: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { pcorr { solver GAMG; tolerance 1e-06; relTol 0.01; smoother DICGaussSeidel; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 50; } pFinal { solver GAMG; tolerance 1e-06; relTol 0; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } "(U|k|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } "(U|k|epsilon)Final" { $U; tolerance 1e-05; relTol 0; } } PIMPLE { nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } relaxationFactors { fields { } equations { "U.*" 1; "k.*" 1; "epsilon.*" 1; } } // ************************************************** *********************** // |
So I add to my fvSolution the part that was missing. But I go another error that I can't solve.
--> FOAM FATAL IO ERROR: [6] keyword div((nuEff*dev(T(grad(U))))) is undefined in dictionary "IOstream.divSchemes" My fvSchemes is the following: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(alpha) Gauss linear; } divSchemes { default none div(rho*phi,U) Gauss vanLeerV; div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss vanLeer; div(phi,U) Gauss linear; div(phi,epsilon) Gauss linear div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; pcorr; alpha; } Can you help me? |
Semicolon after "div(phi,epsilon) Gauss linear" is missing (so the next line with "div((nuEff*dev(T(grad(U))))) Gauss linear;" is eaten by it, and as a result you have got error message about undefined keyword). |
Oh, lack of attention, that's embarrassing! Thank you so much for your help!
