value of nu in icoFoam
Old   July 24, 2015, 06:55
Default value of nu in icoFoam
vipin
vipin1431 is on a distinguished road
hey
I am new to openFoam. I am trying to solve flow through pipe with constant heat flux and constant wall temperature and got the answer but when I check i found that value of nu 0.01 but actual value of nu for water (kinematic Viscosity) is 0.000001 so I changed it and now m getting the answer. please help me to sort this out
I had modified icoFoam for solving this
thanks in advanced
vipin
vipin1431 is offline   Reply With Quote
Old   July 31, 2015, 06:37
Fabian Roesler
fabian_roesler is on a distinguished road
icoFoam has the basic cavity tutorial case. This lid driven cavity tutorial was designed to look good and not to give the correct results. The case runs flawless with nu = 0.01 and gives nicer results in terms of colourful pictures. That's all
Why did you modify icoFoam instead of using buoyant solvers or use scalar transport on a converged flow field?
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   July 31, 2015, 09:06
vipin
Cheers
Fabian
thanks fabian for reply
actually I am new to openFoam and trying to solve various cases and I dont hv any idea about buoyantFoam that's y I modified icoFoam . now I had added temperature field in icoFoam and it is working fine.
thank you
vipin
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
icoFoam won't run while Paraview is running MikeHersee OpenFOAM Running, Solving & CFD 2 January 6, 2015 05:06
Simulating Dam Break problem with icoFoam darthcoder OpenFOAM Running, Solving & CFD 3 August 27, 2013 13:41
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
