mapFields produces '-' entry in BC files. Unable to run simulation! |
June 3, 2016, 04:28 |
Charles K.
Rep Power: 10 |
Hello everyone,
I want to initialize a case with mapFields but when I try to run the mapped case or decompose it for parallel run, the following message occurs : Code:
--> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 11379511 the punctuation token '-' file: .../run/Unabhaengigkeitsstudie/Korrektur/3000/p at line 11379511. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting I used this command to map a consistent case (same geometries): Code:
mapFields -consistent <source case> Cheers! Charles |
Display Modes | |
Shall I leave one core free when I run CFD simulation? | Pierre1 | Main CFD Forum | 1 | March 12, 2015 04:46 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 04:37 |
