Specify refinement region directly during run time?
Old   July 27, 2015, 18:06
Default Specify refinement region directly during run time?
Chenguang Zhang
Taozi is on a distinguished road
Dear All,
I am wondering if it's possible to programically control the region of mesh refinement. Suppose you have a moving object and you can obtain it's location (x, y, z) at anytime, then can you directly specify in code a region around this object (like (x-1, y-1, z-1) to (x+1, y+1, z+1)) to be refined to a certain level n?
I think by default the mesh refinement region is based on certain criteria specified by the user (mostly gradient of something), but in some cases all details in a certain region are needed, like the one I mentioned. In addition, I guess directly specifying the region is faster as it saves OpenFOAM from finding the region numerically.
Any discussion or suggestion is welcomed!
Regards,
Taozi
Taozi is offline   Reply With Quote
Old   July 28, 2015, 11:51
Chenguang Zhang
I will answer my own question, I just realized that I can create a separate volScalarField and let dynamic mesh use this field to refine the mesh, and this field can be updated arbitrarily -- such as using a changing location.
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
