October 28, 2017, 23:04 |
Multi-grading of a block
Sungbae Lee
Rep Power: 8 |
Hello
I am reading the OpenFOAM Guide and in Multi-grading of a block section I have some questions blocks ( hex (0 1 2 3 4 5 6 7) (100 300 100) simpleGrading (1 2 3); ); - split the block into 3 divisions in the y-direction, representing 20%, 60% and 20% of the block length; - include 30% of the total cells in the y-direction (300) in each divisions 1 and 3 and the remaining 40% in division 2; - apply 1:4 expansion in divisions 1 and 3, and zero expansion in division 2. We can specify this by replacing the y-direction expansion ratio "2" in the example above with the following: blocks ( hex (0 1 2 3 4 5 6 7) (100 300 100) simpleGrading ( 1 // x-direction expansion ratio ( (0.2 0.3 4) // 20% y-dir, 30% cells, expansion =4 (0.6 0.4 1) // 60% y-dir, 40% cells, expansion =1 (0.2 0.3 0.25) // 20% y-dir, 30% cells, expansion =0.25 ) 3 // z-direction expansion ratio ( ); I don't understand what Guide says... could anyone rephrase or explain what guide says? Thank you |
[ICEM] Hexa Multi Block Meshing | khedar | ANSYS Meshing & Geometry | 1 | October 22, 2016 18:49 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
when I use multi block the condition of stability can not be fulfilled | mostafa_khan | FLOW-3D | 2 | April 19, 2012 12:17 |
multi block error | ava | FLOW-3D | 3 | December 12, 2011 11:06 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
