Premixed heptane-air combustion in a diesel engine (HCCI-dieselEngineFoam) |
November 25, 2011, 10:23 |
Ayhan Eses
Rep Power: 17 |
Dear Foamers/masters,
I would like to model premixed heptane-air combustion in a diesel engine (HCCI).
C7H16 + 11O2 => 7CO2 + 8H2O 5.00E+8 0.0 15780.0! 1
I used decomposePar Code:
numberOfSubdomains 8; method simple; simpleCoeffs { n (4 2 1); delta 0.001; } The time period between (-180) and (-35) seems reasonable. It's ok. When it came to (-35) on 22.Nov.2011-18.41 I changed controlDict files to reduce Co number. //for (-180,-35) deltaT 0.05; //for (-35, 30) deltaT 2.5e-06; //for (-180,-35) writeInterval 5.0; //for (-35, 30) writeInterval 1.0; //for (-180,-35) adjustTimeStep no; //for (-35, 30) adjustTimeStep yes; It was started(from -35) again 22.Nov.2011-19.12 It came to -19.999787 22.Nov.2011-21.40 The time period between (-35) (19.999787) seems reasonable. It's ok. Pressure and temperature values seem normal. But now on 24.Nov.2011-16.26 it is at -19.7257779 and still running. Just 0,2740091 degree difference took 1 day 18 hour 46 min. time period. Is that last situation normal? What should I do to fix this? I tried to describe my problem more clearly. I hope you understand what I mean. If you give any suggestion/solution, I would be very pleased. I am looking forward to hearing from you soon. Thanks in advance. Best regards. Ayhan ---------------------------------------------------------------------------- engineCompRatio Code:
ayhan@ayhan:~/Masaüstü/tutorials öğesine bağlantı/dizelim2015-12N-8-islemci-22112011$ engineCompRatio /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : engineCompRatio Date : Nov 24 2011 Time : 14:52:32 Host : ayhan PID : 1614 Case : /home/ayhan/OpenFOAM/ayhan-2.0.1/run/tutorials/dizelim2015-12N-8-islemci-22112011 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create engine time Create mesh for time = -180 Selecting engineMesh layered deckHeight: 0.0617697 piston position: -0.00374205 CA = 180 deltaZ = 0 clearance: 0.0655117 Piston speed = 0 m/s CA = 360 deltaZ = 0.068 clearance: -0.00248827 Piston speed = 4.98667 m/s Vmax = 0.000408381, Vmin = 2.66865e-05 Vmax/Vmin = 15.3029 End Code:
checkMesh Code:
ayhan@ayhan:~/Masaüstü/tutorials öğesine bağlantı/dizelim2015-12N-8-islemci-22112011$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : checkMesh Date : Nov 24 2011 Time : 14:53:11 Host : ayhan PID : 1625 Case : /home/ayhan/OpenFOAM/ayhan-2.0.1/run/tutorials/dizelim2015-12N-8-islemci-22112011 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = -180 Time = -180 Mesh stats points: 32397 faces: 87320 internal faces: 77944 cells: 27544 boundary patches: 4 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 27544 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "-180/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology liner 2596 2866 ok (non-closed singly connected) piston 1326 1400 ok (non-closed singly connected) cylinderHead 2184 2260 ok (non-closed singly connected) default-exterior 3270 3421 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.04301 -0.0429955 -0.00721194) (0.04301 0.0429955 0.0679594) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.58789e-19 2.28627e-19 1.8564e-19) OK. Max cell openness = 2.43625e-16 OK. Max aspect ratio = 28.098 OK. Minumum face area = 1.24075e-07. Maximum face area = 2.97139e-05. Face area magnitudes OK. Min volume = 1.03618e-10. Max volume = 9.1877e-08. Total volume = 0.000408381. Cell volumes OK. Mesh non-orthogonality Max: 83.9266 average: 30.6664 *Number of severely non-orthogonal faces: 1724. Non-orthogonality check OK. <<Writing 1724 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 3.36545 OK. Mesh OK. End Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.x-29c61267b203 Exec : dizelim2015 -parallel Date : Nov 22 2011 Time : 16:52:32 Host : d135.uybhmitu.edu PID : 3461 Case : dizelim2015-12N-8-islemci-22112011 nProcs : 8 Slaves : 7 ( : : : : : ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create engine time Create mesh for time = -180 Selecting engineMesh layered deckHeight: 0.0617697 piston position: -0.00374205 Reading thermophysicalProperties Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics> Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysics>> Selecting chemistryReader chemkinReader ODEChemistryModel: Number of species = 5 and reactions = 1 Selecting ODE solver SIBS Reading field U Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Creating field DpDt Reading g Reading combustion properties Courant Number mean: 0 max: 0 Total cylinder mass: 0.0003676 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Starting time loop Courant Number mean: 0 max: 0 Krank acisi = -179.95 KA-derece deltaZ = 9.21597e-09 clearance: 0.0655117 Piston speed = 0.00243302 m/s Solving chemistry , T = 373, p = 95600, C7H16 = 0.0169514 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for C7H16, Initial residual = 0.999971, Final residual = 6.261e-14, No Iterations 9 DILUPBiCG: Solving for O2, Initial residual = 1, Final residual = 6.26118e-14, No Iterations 9 DILUPBiCG: Solving for CO2, Initial residual = 1, Final residual = 6.26118e-14, No Iterations 9 DILUPBiCG: Solving for H2O, Initial residual = 1, Final residual = 6.26118e-14, No Iterations 9 DILUPBiCG: Solving for hs, Initial residual = 1, Final residual = 0.00217333, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0580049, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.0412122, Final residual = 0.00206164, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.57257e-08, global = 5.55614e-09, cumulative = 5.55614e-09 PIMPLE: iteration 2 DILUPBiCG: Solving for C7H16, Initial residual = 0.0028216, Final residual = 5.7904e-13, No Iterations 8 DILUPBiCG: Solving for O2, Initial residual = 0.0014441, Final residual = 1.22784e-13, No Iterations 8 DILUPBiCG: Solving for CO2, Initial residual = 3.55091e-05, Final residual = 7.97566e-13, No Iterations 6 DILUPBiCG: Solving for H2O, Initial residual = 3.55084e-05, Final residual = 7.97231e-13, No Iterations 6 DILUPBiCG: Solving for hs, Initial residual = 0.0336152, Final residual = 7.63924e-05, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.0497545, Final residual = 0.00252405, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.00501676, Final residual = 0.000458723, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 4.25382e-09, global = 1.59641e-09, cumulative = 7.15255e-09 PIMPLE: iteration 3 DILUPBiCG: Solving for C7H16, Initial residual = 0.00257326, Final residual = 2.46875e-13, No Iterations 8 DILUPBiCG: Solving for O2, Initial residual = 0.00139858, Final residual = 4.01771e-13, No Iterations 8 DILUPBiCG: Solving for CO2, Initial residual = 4.88702e-07, Final residual = 2.08857e-15, No Iterations 6 DILUPBiCG: Solving for H2O, Initial residual = 4.8861e-07, Final residual = 2.10063e-15, No Iterations 6 DILUPBiCG: Solving for hs, Initial residual = 0.00744226, Final residual = 2.14878e-06, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.011001, Final residual = 0.000754799, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.00141697, Final residual = 6.05589e-05, No Iterations 3 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.87022e-10, global = 3.09467e-10, cumulative = 7.46201e-09 DILUPBiCG: Solving for epsilon, Initial residual = 0.00173338, Final residual = 2.16273e-06, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 6.99123e-07, No Iterations 4 Mean pressure:95600.1 Mean temperature:373 Mean u':1.63224 ExecutionTime = 1.63 s ClockTime = 5 s : : : : : Courant Number mean: 0.00451027 max: 0.0533268 Krank acisi = -35 KA-derece deltaZ = 2.11031e-05 clearance: 0.00528321 Piston speed = 5.57122 m/s Solving chemistry , T = 382.207, p = 96283.4, C7H16 = 0.0169512 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for C7H16, Initial residual = 0.0645808, Final residual = 1.43178e-13, No Iterations 8 DILUPBiCG: Solving for O2, Initial residual = 0.0645809, Final residual = 1.46181e-13, No Iterations 8 DILUPBiCG: Solving for CO2, Initial residual = 0.0645809, Final residual = 2.20095e-13, No Iterations 8 DILUPBiCG: Solving for H2O, Initial residual = 0.0645809, Final residual = 2.20095e-13, No Iterations 8 DILUPBiCG: Solving for hs, Initial residual = 0.0426634, Final residual = 8.38464e-05, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.005583, Final residual = 0.000483398, No Iterations 4 DICPCG: Solving for p, Initial residual = 0.000500225, Final residual = 4.84631e-05, No Iterations 6 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.000117224, global = 4.3641e-05, cumulative = 0.0103119 PIMPLE: iteration 2 DILUPBiCG: Solving for C7H16, Initial residual = 3.78284e-05, Final residual = 6.74487e-14, No Iterations 6 DILUPBiCG: Solving for O2, Initial residual = 3.78292e-05, Final residual = 9.34363e-14, No Iterations 6 DILUPBiCG: Solving for CO2, Initial residual = 3.78292e-05, Final residual = 7.20297e-14, No Iterations 7 DILUPBiCG: Solving for H2O, Initial residual = 3.78292e-05, Final residual = 7.20297e-14, No Iterations 7 DILUPBiCG: Solving for hs, Initial residual = 0.000366113, Final residual = 9.65849e-06, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.000138196, Final residual = 1.03483e-05, No Iterations 5 DICPCG: Solving for p, Initial residual = 2.80019e-05, Final residual = 2.65778e-06, No Iterations 5 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.43053e-06, global = 2.95708e-06, cumulative = 0.0103149 PIMPLE: iteration 3 DILUPBiCG: Solving for C7H16, Initial residual = 3.31784e-05, Final residual = 1.54592e-13, No Iterations 6 DILUPBiCG: Solving for O2, Initial residual = 3.31791e-05, Final residual = 8.57671e-14, No Iterations 6 DILUPBiCG: Solving for CO2, Initial residual = 3.31791e-05, Final residual = 5.75564e-13, No Iterations 6 DILUPBiCG: Solving for H2O, Initial residual = 3.31791e-05, Final residual = 5.75564e-13, No Iterations 6 DILUPBiCG: Solving for hs, Initial residual = 0.000153014, Final residual = 3.74179e-07, No Iterations 1 DICPCG: Solving for p, Initial residual = 2.08601e-05, Final residual = 1.8431e-06, No Iterations 5 DICPCG: Solving for p, Initial residual = 5.37536e-06, Final residual = 6.35646e-07, No Iterations 4 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.53798e-06, global = 2.68049e-07, cumulative = 0.0103151 DILUPBiCG: Solving for epsilon, Initial residual = 0.00263629, Final residual = 4.19019e-06, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.00292238, Final residual = 8.76681e-06, No Iterations 1 Mean pressure:2.14728e+06 Mean temperature:974.471 Mean u':1.69924 ExecutionTime = 3810.6 s ClockTime = 6535 s |
August 19, 2015, 10:01 |
Rep Power: 10 |
hi ayhan515,
I want to run a HCCI,my thesis topic, engine .I can't fix my favorite compression .In fact I don't know how specify Vmin(clearance volume) and Vmax. please help me out. |
August 21, 2015, 07:44 |
Rep Power: 10 |
Hi ayhan515,
Changing your mesh size maybe can help you. |
Diesel Engine combustion chamber analysis | sachinthakre | FLUENT | 12 | August 13, 2013 14:14 |
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) | kelvinlim | Main CFD Forum | 2 | January 26, 2012 22:19 |
Diesel Engine Combustion Analysis | fluidsuser | FLUENT | 0 | December 1, 2010 21:29 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
diesel engine spray and combustion | usker | Siemens | 6 | April 24, 2006 22:36 |
