Running parallel case after parallel meshing with snappyHexMesh?
I am working on simulating steady state resistance for ship hydrodynamics, using LTSInterFoam, and meshing with snappyHexMesh. In order to speed up the meshing process and use resources to capacity, I am meshing in parallel, which works fine, until I try to run. My exact process is:
When I try to run the solver, it fails with a multitude of errors, complaining that it cant find faces, that mesh sizes are not the same etc. However, I tried to run reconstructParMesh, followed by again decomposing mesh, which worked, but led to me loosing the boundary layer refinement. Have any of you succeeded in running a parallel solver directly after parallel meshing with snappyHexMesh? Do you have any ideas of what might be causing this? EDIT: I figured it out. I just needed to run "patchSummary" to set the boundary conditions on the mesh after snapping and layer insertion! Best regards, Adam |
