January 13, 2016, 08:22 |
#41 |
ok
Rep Power: 13 |
Hello Woj3x,
the transportProperties and the rheologyProperties files are shown Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // nu nu [0 2 -1 0 0 0 0] 0.513; // for Re = 100 rho rho [1 -3 0 0 0 0 0] 1000; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object rheologyProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // planeStress no; //No for 3D, Yes for 2D rheology { type linearElastic; rho rho [1 -3 0 0 0 0 0] 7.82e3; E E [1 -1 -2 0 0 0 0] 2.0e10; //Young's modulus--> elasticity value nu nu [0 0 0 0 0 0 0] 0.265; //Poisson's ratio omega omega [0 0 0 0 0 0 0] 105; // rad/s thickness thickness [0 1 0 0 0 0 0] 0.1; } // ************************************************************************* // Many thanks Maimouna |
January 19, 2016, 09:19 |
#42 |
ok
Rep Power: 13 |
Hi All,
could you please help me to answer the following questions 1. What is the easiest way to mesh the 3D case (picture attached)? 2. Is blockMesh is helpful in that case? 3. If yes, how could start? 4. Is there any easy way to change the blockMeshDict file for the 2D case (attached) to 3D case according to its dimensions if the blockMeshDict file for fluid and solid are shown respectively Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1;//dimensions in meters --> conversion 1 vertices ( (0 0 0) //0 (4.5 0 0) //1 (5.5 0 0) //2 (9.5 0 0) //3 (13 0 0) //4 (19.5 0 0) //5 (19.5 2 0) //6 (19.5 5.5 0) //7 (19.5 5.97 0) //8 (19.5 6.03 0) //9 (19.5 6.5 0) //10 (19.5 10 0) //11 (19.5 12 0) //12 (13 12 0) //13 (9.5 12 0) //14 (5.5 12 0) //15 (4.5 12 0) //16 (0 12 0) //17 (0 10 0) //18 (0 6.5 0) //19 (0 5.5 0) //20 (0 2 0) //21 (4.5 10 0) //22 (5.5 10 0) //23 (9.5 10 0) //24 (13 10 0) //25 (4.5 6.5 0) //26 (5.5 6.5 0) //27 (9.5 6.5 0) //28 (13 6.5 0) //29 (5.5 6.03 0) //30 (9.5 6.03 0) //31 (13 6.03 0) //32 (5.5 5.97 0) //33 (9.5 5.97 0) //34 (13 5.97 0) //35 (4.5 5.5 0) //36 (5.5 5.5 0) //37 (9.5 5.5 0) //38 (13 5.5 0) //39 (4.5 2 0) //40 (5.5 2 0) //41 (9.5 2 0) //42 (13 2 0) //43 (0 0 0.05) //44 <== 0 (4.5 0 0.05) //45 <== 1 (5.5 0 0.05) //46 <== 2 (9.5 0 0.05) //47 <== 3 (13 0 0.05) //48 <== 4 (19.5 0 0.05) //49 <== 5 (19.5 2 0.05) //50 <== 6 (19.5 5.5 0.05) //51 <== 7 (19.5 5.97 0.05) //52 <== 8 (19.5 6.03 0.05) //53 <== 9 (19.5 6.5 0.05) //54 <== 10 (19.5 10 0.05) //55 <== 11 (19.5 12 0.05) //56 <== 12 (13 12 0.05) //57 <== 13 (9.5 12 0.05) //58 <== 14 (5.5 12 0.05) //59 <== 15 (4.5 12 0.05) //60 <== 16 (0 12 0.05) //61 <== 17 (0 10 0.05) //62 <== 18 (0 6.5 0.05) //63 <== 19 (0 5.5 0.05) //64 <== 20 (0 2 0.05) //65 <== 21 (4.5 10 0.05) //66 <== 22 (5.5 10 0.05) //67 <== 23 (9.5 10 0.05) //68 <== 24 (13 10 0.05) //69 <== 25 (4.5 6.5 0.05) //70 <== 26 (5.5 6.5 0.05) //71 <== 27 (9.5 6.5 0.05) //72 <== 28 (13 6.5 0.05) //73 <== 29 (5.5 6.03 0.05) //74 <== 30 (9.5 6.03 0.05) //75 <== 31 (13 6.03 0.05) //76 <== 32 (5.5 5.97 0.05) //77 <== 33 (9.5 5.97 0.05) //78 <== 34 (13 5.97 0.05) //79 <== 35 (4.5 5.5 0.05) //80 <== 36 (5.5 5.5 0.05) //81 <== 37 (9.5 5.5 0.05) //82 <== 38 (13 5.5 0.05) //83 <== 39 (4.5 2 0.05) //84 <== 40 (5.5 2 0.05) //85 <== 41 (9.5 2 0.05) //86 <== 42 (13 2 0.05) //87 <== 43 ); blocks ( hex (0 1 40 21 44 45 84 65) (30 15 1) simpleGrading (1 1 1) //1 hex (1 2 41 40 45 46 85 84) (15 15 1) simpleGrading (1 1 1) //2 hex (2 3 42 41 46 47 86 85) (30 15 1) simpleGrading (1 1 1) //3 hex (3 4 43 42 47 48 87 86) (35 15 1) simpleGrading (1 1 1) //4 hex (4 5 6 43 48 49 50 87) (50 15 1) simpleGrading (10 1 1) //5 hex (43 6 7 39 87 50 51 83) (50 8 1) simpleGrading (10 1 1) //6 hex (42 43 39 38 86 87 83 82) (35 8 1) simpleGrading (1 1 1) //7 hex (41 42 38 37 85 86 82 81) (30 8 1) simpleGrading (1 1 1) //8 hex (40 41 37 36 84 85 81 80) (15 8 1) simpleGrading (1 1 1) //9 hex (21 40 36 20 65 84 80 64) (30 8 1) simpleGrading (1 1 1) //10 hex (20 36 26 19 64 80 70 63) (30 2 1) simpleGrading (1 1 1) //11 hex (37 38 34 33 81 82 78 77) (30 2 1) simpleGrading (1 1 1) //12 hex (38 39 35 34 82 83 79 78) (35 2 1) simpleGrading (1 1 1) //13 hex (39 7 8 35 83 51 52 79) (50 2 1) simpleGrading (10 1 1) //14 hex (35 8 9 32 79 52 53 76) (50 2 1) simpleGrading (10 1 1) //15 hex (34 35 32 31 78 79 76 75) (35 2 1) simpleGrading (1 1 1) //16 hex (30 31 28 27 74 75 72 71) (30 2 1) simpleGrading (1 1 1) //17 hex (31 32 29 28 75 76 73 72) (35 2 1) simpleGrading (1 1 1) //18 hex (32 9 10 29 76 53 54 73) (50 2 1) simpleGrading (10 1 1) //19 hex (29 10 11 25 73 54 55 69) (50 15 1) simpleGrading (10 1 1) //20 hex (28 29 25 24 72 73 69 68) (35 15 1) simpleGrading (1 1 1) //21 hex (27 28 24 23 71 72 68 67) (30 15 1) simpleGrading (1 1 1) //22 hex (26 27 23 22 70 71 67 66) (15 15 1) simpleGrading (1 1 1) //23 hex (19 26 22 18 63 70 66 62) (30 15 1) simpleGrading (1 1 1) //24 hex (18 22 16 17 62 66 60 61) (30 13 1) simpleGrading (1 1 1) //25 hex (22 23 15 16 66 67 59 60) (15 13 1) simpleGrading (1 1 1) //26 hex (23 24 14 15 67 68 58 59) (30 13 1) simpleGrading (1 1 1) //27 hex (24 25 13 14 68 69 57 58) (35 13 1) simpleGrading (1 1 1) //28 hex (25 11 12 13 69 55 56 57) (50 13 1) simpleGrading (10 1 1) //29 ); edges ( ); patches ( patch inlet //left ( (17 61 62 18) (18 62 63 19) (19 63 64 20) (20 64 65 21) (21 65 44 0) ) patch outlet //right ( (12 56 55 11) (11 55 54 10) (10 54 53 9) (9 53 52 8) (8 52 51 7) (7 51 50 6) (6 50 49 5) ) patch top //up ( (17 61 60 16) (16 60 59 15) (15 59 58 14) (14 58 57 13) (13 57 56 12) ) patch bottom //down ( (0 44 45 1) (1 45 46 2) (2 46 47 3) (3 47 48 4) (4 48 49 5) ) patch cylinder //solid ( (26 70 71 27) (27 71 74 30) (33 77 81 37) (37 81 80 36) (36 80 70 26) ) patch plate //solid ( (30 74 75 31) (31 75 78 34) (34 78 77 33) ) empty frontAndBackPlanes //ahead behind ( (0 1 40 21) //Block 1 front (1 2 41 40) //Block 2 front (2 3 42 41) //Block 3 front (3 4 43 42) //Block 4 front (4 5 6 43) //Block 5 front (43 6 7 39) //Block 6 front (42 43 39 38) //Block 7 front (41 42 38 37) //Block 8 front (40 41 37 36) //Block 9 front (21 40 36 20) //Block 10 front (20 36 26 19) //Block 11 front (37 38 34 33) //Block 12 front (38 39 35 34) //Block 13 front (39 7 8 35) //Block 14 front (35 8 9 32) //Block 15 front (34 35 32 31) //Block 16 front (30 31 28 27) //Block 17 front (31 32 29 28) //Block 18 front (32 9 10 29) //Block 19 front (29 10 11 25) //Block 20 front (28 29 25 24) //Block 21 front (27 28 24 23) //Block 22 front (26 27 23 22) //Block 23 front (19 26 22 18) //Block 24 front (18 22 16 17) //Block 25 front (22 23 15 16) //Block 26 front (23 24 14 15) //Block 27 front (24 25 13 14) //Block 28 front (25 11 12 13) //Block 29 front (44 45 84 65) //Block 1 back (45 46 85 84) //Block 2 back (46 47 86 85) //Block 3 back (47 48 87 86) //Block 4 back (48 49 50 87) //Block 5 back (87 50 51 83) //Block 6 back (86 87 83 82) //Block 7 back (85 86 82 81) //Block 8 back (84 85 81 80) //Block 9 back (65 84 80 64) //Block 10 back (64 80 70 63) //Block 11 back (81 82 78 77) //Block 12 back (82 83 79 78) //Block 13 back (83 51 52 79) //Block 14 back (79 52 53 76) //Block 15 back (78 79 76 75) //Block 16 back (74 75 72 71) //Block 17 back (75 76 73 72) //Block 18 back (76 53 54 73) //Block 19 back (73 54 55 69) //Block 20 back (72 73 69 68) //Block 21 back (71 72 68 67) //Block 22 back (70 71 67 66) //Block 23 back (63 70 66 62) //Block 24 back (62 66 60 61) //Block 25 back (66 67 59 60) //Block 26 back (67 68 58 59) //Block 27 back (68 69 57 58) //Block 28 back (69 55 56 57) //Block 29 back ) ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1;//dimensions in meters --> conversion 1 vertices ( (5.5 5.97 0) //0--19 (9.5 5.97 0) //1--20 (9.5 6.03 0) //2--22 (5.5 6.03 0) //3--21 (5.5 5.97 0.05) //4--45 (9.5 5.97 0.05) //5--46 (9.5 6.03 0.05) //6--48 (5.5 6.03 0.05) //7--47 ); blocks ( hex (0 1 2 3 4 5 6 7) (30 2 1) simpleGrading (1 1 1) //0 ); edges ( ); patches ( patch plateFix ( (3 7 4 0) ) patch plate ( (3 2 6 7) (6 2 1 5) (1 0 4 5) ) empty frontAndBackPlanes ( (0 1 2 3) (7 6 5 4) ) ); mergePatchPairs ( ); // ************************************************************************* // 5. If blockMesh isn't useful, what about snappyHexMesh? I never used it before. Any answer would be really grateful. Thank you very much. Maimouna |
January 19, 2016, 10:16 |
#43 |
Wojciech Gołąbek
Rep Power: 12 |
I use ICEM CFD for meshing so I can't help you in this but IMO this case isn't so hard, so you can easly handle this with blockMesh but it's gonna be time consuming (it's all depend on your experience with blockMesh). Good option could be to analyze blockMeshDict file from case beamInCrossFlow (it's 3D case from fsiFOAM tutorials). It should be good place to start. Best regards, Wojciech |
January 22, 2016, 13:12 |
#44 |
Wojciech Gołąbek
Rep Power: 12 |
Dear Maimouna,
Could you show me how your chart FD over time looks? how your chart drag forces from time it looks for the case of 2D? Because I'm not sure why this value is negative in my case. Thank you in advance! Dear nctiwary, Your case requires a lot of knowledge about this topic so I suppose it will be better for you to create separate topic. Neverless I suppose that case: beamInCrossFlow could be good place to start. Good luck! Best regards, Wojciech [Moderator note: nctiwary had asked in a ton of threads and all of nctiwary's posts were deleted due to not following the rules.] Last edited by wyldckat; January 31, 2016 at 12:12. Reason: added moderator note |
January 23, 2016, 07:19 |
#45 |
ok
Rep Power: 13 |
Hi Wojciech,
the attached pictures are showed FD with time in two different cases in 2D (same case with different parameters). Kind regards Maimouna |
January 31, 2016, 12:15 |
#46 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick side note: There are a few GUIs for editing the "blockMeshDict" files. One example is this one: http://openfoamwiki.net/index.php/Contrib/SwiftBlock
For more details about blockMesh: https://openfoamwiki.net/index.php/BlockMesh |
January 31, 2016, 12:45 |
#47 |
Wojciech Gołąbek
Rep Power: 12 |
Dear Bruno
Could you tell me why Drag force forom script hronTurekReport.C is negative? I suppose that direction of this force should correspond to the direction of fluid flow. Thank you in advance Wojciech |
January 31, 2016, 12:57 |
#48 | ||
Bruno Santos
Rep Power: 128 |
Greetings Wojciech,
Nonetheless, is the drag force showing you an opposite sign to the fluid flow? If yes, then it's because it's the "drag force": https://en.wikipedia.org/wiki/Drag_%28physics%29 - and I quote: Quote:
Bruno
February 5, 2016, 11:30 |
#49 | |
ok
Rep Power: 13 |
I started learning swiftBlock, but that is not easy to understand in few days. I spent days to understand but I found it so hard.. Sorry, my technical experience and information so poor. Are there any other easy way instead? Any way to change 2D case to 3D case? I never stopped, I'm trying with gmsh, hopefully it will work. But, another question regarding this, How is Allrun file will be looked after gmsh. Allrun is shown below Code:
#!/bin/sh # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions # Get application name application=`getApplication` runApplication -l log.blockMesh.solid blockMesh -region solid runApplication -l log.setSet.solid setSet -case ../solid -batch ../solid/setBatch runApplication -l log.setToZones.solid setsToZones -case ../solid -noFlipMap runApplication blockMesh runApplication setSet -batch setBatch runApplication setsToZones -noFlipMap # Build hronTurekReport function object wmake libso ../hronTurekReport runApplication $application # ----------------------------------------------------------------- end-of-file Many thanks. Maimouna |
February 18, 2016, 11:14 |
3d cantilever beam
#50 |
ok
Rep Power: 13 |
Dear Bruno and others,
I need your help again please, I'm doing 3d beam cantilever case (picture attached). I followed case ''beamInCrossFlow'' case to implement my case (attached). The meshing and running the solid part is ok, he proplem I faced with the fluid part. I think their is something problem in ''interface'' meshing because I got this error message in the log file Code:
--> FOAM FATAL ERROR: Solid face zone name interface-zone not found. Please check your face zone definition. From function in file fluidStructureInterface/fluidStructureInterface.C at line 737. FOAM aborting Aborted (core dumped) Lots of thanks in advanced and regards. Maimouna |
February 18, 2016, 11:32 |
#51 |
Wojciech Gołąbek
Rep Power: 12 |
Dear Maimouna,
In file setBatch you can define name for FSI interface. In your file FSI interface is called "plate" so fsiFOAM is trying to find boundary "plate". You need to correct this (change setBatch or name in your BC). I also have a few problems with this solver so I don't have time to test your case sorry but I hope that this will help you. Best regards, Wojciech |
February 18, 2016, 12:12 |
#52 |
ok
Rep Power: 13 |
Dear Wojciech,
thanks for your quick replay. I already did what you suggested, may be I attached wrong setBatch file with the case. The correct one is Code:
faceSet interfaceZone new patchToFace interface quit Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.1-f61aab88e799 Exec : checkMesh Date : Feb 18 2016 Time : 17:00:36 Host : owner-HP-Pavilion-Sleekbook-15-PC PID : 4743 CtrlDict : /home/owner/foam/foam-extend-3.1/etc/controlDict Case : /home/owner/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/3dBeamInCrossFlow/fluid nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats all points: 28230 live points: 28230 all faces: 76976 live faces: 76976 internal faces: 69024 cells: 24448 boundary patches: 9 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 23760 prisms: 688 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Area [m^2] Surface topology top 0 0 0 ok (empty) bottom 688 783 220 ok (non-closed singly connected) outlet 320 361 104.5 ok (non-closed singly connected) inlet 256 289 104.5 ok (non-closed singly connected) cylinder 512 578 8 ok (non-closed singly connected) interface 320 369 121 ok (non-closed singly connected) back 2800 2974 204 ok (non-closed singly connected) frontPlane 2800 2974 372.035 ok (non-closed singly connected) defaultFaces 256 297 55 ok (non-closed singly connected) Checking geometry... This is a 2-D mesh Overall domain bounding box (0 0 0) (20 11 11) Mesh (non-empty, non-wedge) directions (0 1 1) Mesh (non-empty) directions (0 1 1) Mesh (non-empty, non-wedge) dimensions 2 All edges aligned with or perpendicular to non-empty directions. Boundary openness (0 1.46407e-16 3.14327e-15) Threshold = 1e-06 OK. ***High aspect ratio cells found, Max aspect ratio: 4.6875e+09, number of cells 24448 Threshold = 1000 Writing 24448 cells with high aspect ratio to set highAspectRatioCells Minumum face area = 0.0078125. Maximum face area = 0.6875. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -0.214844, Number of negative volume cells: 24448 Writing 24448 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 158.784 Threshold = 70 ***Number of non-orthogonality errors: 69024. Writing 69024 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 146000 faces are incorrectly oriented. Writing 76976 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 0.851667 OK. Failed 4 mesh checks. End Kind regards Maimouna |
February 22, 2016, 11:26 |
#53 |
ok
Rep Power: 13 |
Hi all,
the blockMesh and checkMesh utilities for both fluid and solid are ok, but the problem in the log file still the same Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.1-f61aab88e799 Exec : fsiFoam Date : Feb 22 2016 Time : 16:06:41 Host : owner-HP-Pavilion-Sleekbook-15-PC PID : 7801 CtrlDict : /home/owner/foam/foam-extend-3.1/etc/controlDict Case : /home/owner/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/3dBeamInCrossFlow/fluid nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian Selecting motion diffusion: quadratic Selecting motion diffusion: inverseDistance Reading stress mesh Creating fixed displacement boundary condition Creating traction displacement boundary conditions Creating fixed displacement boundary condition Selecting rheology model linearElastic Creating constitutive model --> FOAM FATAL ERROR: Solid face zone name interface-zone not found. Please check your face zone definition. From function in file fluidStructureInterface/fluidStructureInterface.C at line 737. FOAM aborting Aborted (core dumped) Lots of thanks in advanced and regards. Maimouna |
February 22, 2016, 12:37 |
#54 | ||
Wojciech Gołąbek
Rep Power: 12 |
Dear Maimouna,
In solid setBatch looks: Quote:
I am also not sure if in this solver both FSI interfaces don't needs to have same name. Best regards, Wojciech |
February 23, 2016, 05:17 |
#55 |
ok
Rep Power: 13 |
Hi Wojciech,
I already changed the interface-zone name in both setBatch files as Code:
faceSet interfaceZone new patchToFace interface quit Kind regards Maimouna |
February 23, 2016, 07:14 |
#56 | |
Wojciech Gołąbek
Rep Power: 12 |
Hi Maimouna,
I suppose that I found file with problem. In fluid/constant/fsiProperties you've got: Quote:
Best regards, Wojciech Last edited by Woj3x; February 23, 2016 at 12:19. |
February 23, 2016, 14:23 |
#57 |
ok
Rep Power: 13 |
Many thanks Wojciech, you are right, I was silly with that error, it is solved now. But there is another one needs to sort out
--> FOAM FATAL ERROR: Master point addressing is not correct Regarding your request about tetFemSolution, I don't know more than than it used for moving mesh because the motion solver is FEM and the flow solver is FVM. Since motionU is a tetFem field, the number of boundary locations is be different and mapping is required. I saved that from some time ago in my note and I used it for every moving mesh solver. I hope that would help. Kind regards Maimouna |
February 26, 2016, 12:01 |
#58 |
ok
Rep Power: 13 |
Hi All,
have a good day. Any idea please to solve the the last error posted in #57. What's the problem? Any answer would be really appreciated. Best regards Maimouna |
February 26, 2016, 17:27 |
#59 |
Wojciech Gołąbek
Rep Power: 12 |
Hi Maimouna,
I didn't have problem like this so I have no idea how to fix this. I would consider to make this case again. You've done a lot of changes in this case when you used trial and error method to solve problems and you could accidentally create this error. Isn't in log.fsiFoam any additional information about this error? Best regards, Wojciech Last edited by Woj3x; February 26, 2016 at 18:55. |
March 8, 2016, 19:13 |
#60 | |
Wojciech Gołąbek
Rep Power: 12 |
Hi all,
Maimouna, did you solve this problem? I've got same one right now: Quote:
Thank you in advance Best regards, Wojciech |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
