2nd Order Convergence Problem for 3D Airfoil
5 Attachment(s)
Hi everyone,
I am working on simulating flow over 3D airfoil. I solved my case in first order Simplefoam but now I want to solve it in second order. But I didnt verify my first order result, it seemed good to me. I tried different schemes only one of it converged but the residuals were higher than my first order. I used my converged result from first order simplefoam as initial guess. I only changed divergent schemes in simplefoam to increase the order. I put them at the end of this thread. (only the last one worked) I tried icofoam but courant number diverged after some time. My case is laminar. I used my converged result from first order simplefoam as initial guess. I would be very greatfull if someone help me to solve my problem, because I have been working on this for long time. I tried the schemes below: divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,k) Gauss linear; div(phi,epsilon) Gauss linear; div(phi,R) Gauss linear; div(R) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; div(phi,k) Gauss linear; div(phi,epsilon) Gauss linear; div(phi,R) Gauss linear; div(R) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; } ,divSchemes { default none; div(phi,U) Gauss SFCD; div(phi,k) Gauss linear; div(phi,epsilon) Gauss linear; div(phi,R) Gauss linear; div(R) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,R) Gauss limitedLinear 1; div(R) Gauss linear ; div(phi,nuTilda) Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; } divSchemes { default none; div(phi,U) Gauss QUICKV leastSquares; div(phi,k) Gauss linear; div(phi,epsilon) Gauss linear; div(phi,R) Gauss linear; div(R) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear upwind; } divSchemes { default none; div(phi,U) Gauss linearUpwindV leastSquares; div(phi,k) Gauss linear; div(phi,epsilon) Gauss linear; div(phi,R) Gauss linear; div(R) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear upwind; } I couldnt attach my case file so I am attaching my residualsi checkmesh results and BCs. 0/p dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { wall { type zeroGradient; } airfoil { type zeroGradient; } sides { type freestreamPressure; } } 0/U dimensions [0 1 -1 0 0 0 0]; internalField uniform (1 0 0); boundaryField { wall { type fixedValue; value uniform (0 0 0); } airfoil { type fixedValue; value uniform (0 0 0); } sides { type freestream; freestreamValue uniform (1 0 0); } } Time = 0 Mesh stats points: 370455 faces: 4159775 internal faces: 4037721 cells: 2049374 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 2049374 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology airfoil 72504 36528 ok (non-closed singly connected) sides 2470 1393 ok (non-closed singly connected) wall 47080 23974 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.85 -0.5 -1.66533e-16) (1.05 0.5 0.27) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.59378e-17 6.14025e-17 -3.65029e-15) OK. Max cell openness = 3.74888e-16 OK. Max aspect ratio = 6.7235 OK. Minumum face area = 3.48265e-09. Maximum face area = 0.00154965. Face area magnitudes OK. Min volume = 9.66928e-14. Max volume = 2.01324e-05. Total volume = 0.512781. Cell volumes OK. Mesh non-orthogonality Max: 58.2936 average: 19.726 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.715771 OK. Coupled point location match (average 0) OK. Mesh OK. End Thank you |
1st order has more numerical dissipation than 2nd order, i.e. you spuriously solve for a case with artificially higher viscosity. Also, you damp all kinds of effects by 1st order schemes. Maybe your case just isn't stationary, which only appears in 2nd order?
Edit: Ok, you should post the whole schemes file and also the fvOptions. And some log output would be beneficial. Please use the "code" button (under "->Go Advanced') to post code - don't just copy it to the text box. Also: Why do you specify all the different div-Schemes for a laminar case? This is pretty confusing. |
