September 9, 2015, 09:15 |
using GMSH in OpenFoam
Subhasree
Rep Power: 12 |
Hi everyone,
I have used GMSH to mesh an external flow domain over a model building and using pisoFoam to simulate its flow. I am simulating laminar flow at sea-level conditions having velocity of 10 m/s. I have converted the mesh from GMSh to OpenFoam, but on using pisoFoam solver I am getting the following error: Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon Starting time loop Time = 0.005 Courant Number mean: 0.166758 max: 7.5028 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) Please help me!!! |
September 11, 2015, 02:48 |
Rep Power: 11 |
Courant number is too high. decrease deltaT in system/controlDict until the max Courant number will be less than 1.
September 15, 2015, 08:00 |
Subhasree
Rep Power: 12 |
Thank you for the reply. Problem solved!
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[Gmsh] MVG with Gmsh for OpenFOAM | fportela | OpenFOAM Meshing & Mesh Conversion | 2 | March 26, 2013 03:57 |
[Technical] Salome + Gmsh or enGrid for OpenFOAM? | wwrfd | OpenFOAM Meshing & Mesh Conversion | 2 | July 21, 2011 10:38 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
[Gmsh] ANSYS GMSH OpenFOAM | gtg627e | OpenFOAM Meshing & Mesh Conversion | 3 | December 21, 2007 03:41 |
