How to run DTCHull
I am new to OpenFoam and am trying to run a range of examples.
I am trying to run DTCHull case, and I don't know how to do it. I did the following steps: - blockMesh - snappyHexMesh -overwrite - decomposePar Until here everything is ok. How should I proceed now? Can anyone help me out here? Thanks in advance |
you don't have to run them step by step. Just run the Allrun-Script. Alternatively, you can open this file in text editor to see what the single steps are and run them one after the other- maybe this helps to learn and understand what is done ;)
PS: this case has a rather complex meshing procedure, so it is not the best case for getting started with openfoam. i recommend you to run (/try to understand) some easier tutorial cases first.
a more basic sequence is something like this: -blockmesh (create the background mesh) -snappyhexmesh (refine and snap to your geometry) -run the main solver additional steps are needed depending on the solver and problem, e.g. setFields to tell interDyMFoam where there is water and where there is air in the initial state. unfortunately, openfoam is not that easy to get started, but with some reading and some trial and error, you will soon find out how things work. good luck and keep on trying ;) |
OK! Thanks a lot for your replay! I will keep on trying :)
I ran the DTCHull case of the easy way (Allrun-Script) and appears this error: ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0xa7204e8): Error reading line 23 of /home/hmc_ubuntu/OpenFOAM/openfoam240/tutorials/multiphase/interDyMFoam/ras/DTCHull1/0/U: Unexpected token 0 ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0xa7204e8): Error reading line 25 of /home/hmc_ubuntu/OpenFOAM/openfoam240/tutorials/multiphase/interDyMFoam/ras/DTCHull1/0/k: Unsupported directive includeEtc ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0xa7204e8): Error reading line 25 of /home/hmc_ubuntu/OpenFOAM/openfoam240/tutorials/multiphase/interDyMFoam/ras/DTCHull1/0/nut: Unsupported directive includeEtc ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0xa7204e8): Error reading line 25 of /home/hmc_ubuntu/OpenFOAM/openfoam240/tutorials/multiphase/interDyMFoam/ras/DTCHull1/0/omega: Unsupported directive includeEtc ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0xa7204e8): Error reading line 25 of /home/hmc_ubuntu/OpenFOAM/openfoam240/tutorials/multiphase/interDyMFoam/ras/DTCHull1/0/p_rgh: Unsupported directive includeEtc ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6467 vtkOpenFOAMReaderPrivate (0xa7204e8): Error reading line 25 of /home/hmc_ubuntu/OpenFOAM/openfoam240/tutorials/multiphase/interDyMFoam/ras/DTCHull1/0/pointDisplacement: Unsupported directive includeEtc Can anyone help me with this? Thanks in advance |
Raj |
