September 18, 2015, 12:50 |
Modify compressible solver to incompressible
Rep Power: 11 |
Dear Foamers,
I am using twoPhaseEulerfoam right now. In this solver air both phases are treated compressible. I am wondering what changes should I make to change both phases incompressible. I tried to change thermophysicalProperteis in case file but it generate some unphysical result and I found some incompressible algorithms are hard coded into the solver. So would any one know how can I change it for two incompressible phases? Thank you. Ming |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
difference between incompressible k-epsilon model and compressible k-epsilon model | yhy20081016 | OpenFOAM Running, Solving & CFD | 3 | January 19, 2016 07:49 |
what is difference between using compressible solver and incompressible solver | oilsok | OpenFOAM Running, Solving & CFD | 0 | March 23, 2014 01:11 |
Using pressure based solver for compressible flows | aamer | Main CFD Forum | 2 | June 15, 2011 12:45 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 16:51 |
