Error: bad compression specifier 'off', using 'uncompressed'
Like Tree4Likes
  • 4 Post By wyldckat
Old   October 21, 2015, 02:30
Default Error: bad compression specifier 'off', using 'uncompressed'
ASHISH
ashisha is on a distinguished road
Hi
I am using foam extended version 3.1
When I try to run any command like blockMesh, snappyHexMesh it gives following error
--> FOAM Warning :
From function IOstream::compressionEnum(const word&)
in file db/IOstreams/IOstreams/IOstream.C at line 74
Create mesh for time = 0
Plz Help
I am not getting which type of error is this
Thank You
ashisha is offline   Reply With Quote
Old   October 31, 2015, 11:07
Retired Super Moderator
Bruno Santos
Quick answer:
  1. Edit the file "system/controlDict".
  2. Find this line:
    writeCompression off;
  3. Change it to this:
    writeCompression uncompressed;
ashisha, robob, rezachalak and 1 others like this.
Old   June 8, 2020, 06:33
Lukas Fischer
lukasf is on a distinguished road
FYI:
OpenFOAM 4.1 and 6 (etc.) use
The OpenFOAM versions like v1912 use
lukasf is offline   Reply With Quote
The udf.h headers are unable to open- in VISUAL STUDIO 13 sanjeetlimbu Fluent UDF and Scheme Programming 4 May 2, 2016 06:38
[ANSYS Meshing] Meshing 2D axisymetric for dynamic compression sanjeetlimbu ANSYS Meshing & Geometry 9 April 21, 2015 16:41
Binary gives significant performance advantage (Mesh & Solve) glypo OpenFOAM 18 January 1, 2015 14:41
Piston gas compression cob CFX 3 August 27, 2014 04:12
Modelling the heat transfer during compression and cooling of natural gas pano Main CFD Forum 0 December 10, 2010 16:53
