Running distributed simpleFoam with 2 computers |
October 21, 2015, 14:46 |
Cristhian Fuertes
Hello everyone and excuse my english
I'm trying to run pitzDaily using distributed OpenFOAM, I've set up passwordless communication between the 2 nodes (using rsa), mirror disk sharing the pitzDaily folder (using nfs). However I get the following error after using command: Code:
mpirun --hostfile machines -np 16 simpleFoam /home/OpenFOAM/OpenFOAM/run/tutorials/incompressible/simpleFoam/pitzDaily -parallel > log& [openfoam2:11635] [[44716,0],0] mca_oob_tcp_recv_handler: invalid message type: 12 My decomPoseParDict is: Code:
numberOfSubdomains 16; method simple; simpleCoeffs { n (4 2 2); delta 0.001; } distributed yes; roots 2( "/home/OpenFOAM/OpenFOAM/run/tutorials/incompressible/mySimpleFoam/pitzDaily" //master node "/mnt/nfs/pitzDaily" //slave node ); Code:
/home/OpenFOAM/OpenFOAM/run/tutorials/incompressible/mySimpleFoam/pitzDaily and Code:
/mnt/nfs/pitzDaily" //slave node Is there something run with my setup ? |
cluster computing, openfoam, parallel computation |
OF 2.0.1 parallel running problems | moser_r | OpenFOAM Running, Solving & CFD | 9 | July 27, 2022 03:15 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SimpleFoam solver running error | Steinmann | OpenFOAM Running, Solving & CFD | 5 | November 22, 2011 11:25 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
Problem with running FoamX in a distributed environment | susana | OpenFOAM Pre-Processing | 1 | March 28, 2007 17:11 |
