November 18, 2015, 11:11 |
about time step and end time
shukai
I am beginner for stimulation by software. May be it is easy for you, but I can't understand why I need set end time. If I set end time, how can I know whether the stimulation is finished, because the process will be end at time I set.
November 19, 2015, 02:21 |
Anton Kidess
Rep Power: 29 |
For a transient case, your question is trivial, so I assume you are interested in steady state solutions. In that case, think of endTime as a maximum amount of iterations you want to run. The simulation may actually stop before endTime (=maxIters) if you use residualControl. Ideally, you should look at convergence of physical quantities to judge your convergence, e.g. drag or a temperature or similar.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 19, 2015, 06:22 |
shukai
Could you explain how to control it by residual control or there is some literature about it, Because I can't find it. Thank you for you reply
November 19, 2015, 07:05 |
Anton Kidess
Rep Power: 29 |
Most simpleFoam tutorials can serve as an example, e.g. pitzDaily.
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
