May 23, 2019, 10:51 |
calculating view factors
Roman
Rep Power: 12 |
Hello all. I am running the utility viewFactorsGen with the case that is cubic domain by itself. Solid verges and air inside for future running the solver fireFoam. Now I do not need heatflux but only viewfactors from surface to surface. For example, from the bottom side to the upper side. It is for the purpose of the validation. The are many handbooks with the explicit values of the viewfactors from square to square depending of their sizes. As a result of the utility viewFactorsGen I gain the cube each side of it has viewfactor 1. How can I get viewfactor from side to the side? Thanks.
May 27, 2019, 09:08 |
Roman
Rep Power: 12 |
It turned out quite easy. One should use zeroGradient instead of greyDiffusiveRadiationViewFactor b.c. on surfaces which are not under consideration. The result is the correct view factor from square to square.
Good luck! |
Accessing View factors of a patch for postprocessing | pss47 | OpenFOAM Post-Processing | 5 | June 8, 2020 10:53 |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 05:25 |
Where to find the view factors in .sol file? | RuthMcNabb22 | Main CFD Forum | 0 | July 24, 2018 12:53 |
HELP!!! viewFactorsGen is not calculating view factors!! | zfaraday | OpenFOAM Pre-Processing | 0 | September 15, 2014 08:55 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
