How to calculate electric field strength
Like Tree2Likes
  • 1 Post By andrek
  • 1 Post By mike_jaworski
Old   February 17, 2009, 09:30
Default Hi all, 1.: I´m sure that s
Andre Kunze
andrek is on a distinguished road
Hi all,
1.: I´m sure that someone has already figured out how to calculate the electric field strength in openfoam and how to display it with paraview. I´d really appreciate if you could help me with that.
2.: I´m very new to Linux and OpenFoam and currently I´m running the virtual machine version of CAELinux2008 on Windows. So everything should be preinstalled and working, but when I type "wmake" in the console it always says "command not found". So at the moment I´m not getting further with figuring out on my own how to calculate the electric field strength because I can´t compile my own applications. Any idea on the second problem would be appreciated even more.
Best regards
André
andrek is offline   Reply With Quote
Old   February 18, 2009, 03:58
Default Update: Second problem solved.
Andre Kunze
Update: Second problem solved. Now to the first one...
Old   February 18, 2009, 09:59
Default which solver you are using now
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
which solver you are using now? i have i solver to solve the EHD problem.you can get electric field strenth in result, and the solver could be find in OpenFOAM wiki
Regards
wayne
waynezw0618 is offline   Reply With Quote
Old   February 18, 2009, 10:01
Default The potential of an electrosta
Mariam Winkler
mariam is on a distinguished road
The potential of an electrostatic field is calculated using the poisson equation. I think there are examples in the userguide for this type of equation.
To my knowledge electrodynamics cannot be calculated with openfoam.
What is your question about paraview display? Once you calculated the potential, write out it's gradient. Display the magnitude of this gradient, which is the field strength.
Regards,
Mariam
mariam is offline   Reply With Quote
Old   February 18, 2009, 10:59
Default Ok, finally I figured it out n
Andre Kunze
Ok, finally I figured it out now: I added the calculation of the gradient in the .H- and .C-File of electrostaticFoam analogous to the rhoFlux calculation and compiled it. Now I have the electric field as a vector and the magnitude of it in paraview, which is what I wanted.
Salomé, OpenFOAM and paraview are nice tools if you have finally figured out how to work with them ;)
Best regards
André
Old   February 18, 2009, 11:07
Default "To my knowledge electrodynami
Andre Kunze
"To my knowledge electrodynamics cannot be calculated with openfoam."
But it should be possible, shouldn´t it?
Or is there already something in work perhaps?
Old   February 18, 2009, 12:08
Default In order to solve electrodynam
Michael Jaworski
mike_jaworski is on a distinguished road
In order to solve electrodynamics problems, you have to solve the full Maxwell wave equations.
The programming guide does include the ability to put in second order time derivatives on page P-37. This and a laplacian are all you need (provided you have the correct boundary conditions and E-B coupling) to solve the wave equation.
Alternatively, you only need the laplacian operator if you want to solve time-harmonic fields.
c.f. Balanis, "Advanced Engineering Electromagnetics" John Wiley & Sons, 1989.
or other suitable text on the topic.
Regards,
Mike J.
mike_jaworski is offline   Reply With Quote
Old   February 19, 2009, 12:48
Default Hm, something went wrong. I wa
Andre Kunze
Hm, something went wrong. I wanted to add this picture:
Old   February 26, 2009, 08:04
Default Hi all, I have done a littl
Andre Kunze
Hi all,
I have done a little step-by-step guide about how to model a simple geometry and solve for its electric field in CAELinux. It´s written for absolute beginners like me. Would be nice if a real beginner could test it sometime and report back if everything worked out.
step-by-step guide - part 1.pdf
Best regards
André
Old   February 26, 2009, 08:09
Default And here is the second part:
Andre Kunze
And here is the second part: step-by-step guide - part 2.pdf
mm.abdollahzadeh likes this.
Old   February 27, 2009, 01:20
Default Andre and others, I have
  #11
Michael Jaworski
Andre and others,
I have been looking at this capacitance calculation as well and I can't find a source for the discrepancy. I have constructed a much simpler mesh exploiting spherical symmetry and the solver I wrote calculates the field energy a little more simply using only:
dimensionedScalar energyEps = 0.5 * epsilonR*sum(mesh.V()*( magSqr(E) ));
This avoids writing an additional mesh just for the electric field magnitude.
I had also had a hunch that the problem might be numerical accuracy since the resultant energy is on the order of 10<sup>-08</sup>. Rather than solve the phi equation the way it currently is in electrostaticFoam, I have:
fvm::laplacian(epsilonR,phi) + rhoEps
where epsilonR is the permittivity normalized by the numerical value of epsilon0 (8.854e-12). This makes calculating the resultant energy a number of order 1.
The case that has been constructed is done with blockMesh (all files included below) and models a small wedge taken out of the sphere with arc-lengths of 5 degrees on a side. The bottom and top surfaces are constant phi surfaces (100 and 0) and the sides have a zeroGradient BC. I have used various levels of mesh refinement without much improvement from the results below.
The energy/epsilon0 calculated for the case is 0.78461. Multiplying by 1650.1 scales the energy value from the wedge to full sphere and the calculated capacitance is 2.2926 pF. The analytical result is 2.2253pF, a difference of 3%.
I have tried to go through various fvSolution tolerance levels (currently at 1e-10) and fvSchemes but the solution never gets below a 3% error.
So, is 3% error as good as this can get?
Any thoughts on this matter would be greatly appreciated.
Regards,
Mike J.
Old   February 27, 2009, 01:29
  #12
Michael Jaworski
Andre and others,
Regards,
Mike J.
Solver files
case files
Mesh Image
Old   June 17, 2010, 19:50
Default Electrostatic Foam
  #13
Xingzhi You
masspec is on a distinguished road
Hi Mike,
I get one question on the electrostatic foam, and hope you can give some thoughts and help.
First, what is k in rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi) .
I checked the dimension of it and:
k [-1 0 2 0 0 1 0 ] 0.00016
which means the unit is kg-1· s2 ·A, this is not the electric
conductivity unit as simens per meter would be m-3·kg-1·s3 ·A2. And we
can restructure it to be (kg-1S2A)(ASm-3), and ASm-3 is just
Cm-3(coulomb per cubic meter). It seems k is electric conductivity
divided charge density, which makes it unknown to me.
Furthermore,where does that weird 0.00016 come from, it is not any
familiar constant or electric property.
Second, in rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi) equation, the mesh.magSf() gives the magnitude of surface cell area. So rhoFlux would be, if not talk about the k, then surface area times potential
gradient(at the surface normal, which is electric field), which gives:
(electric_conductivity/charge_density)*(area)*(electric_field) =
current/charge-density
This is so weird. Then what does solve fvm::ddt(rho) + fvm::div(rhoFlux, rho) means?
Best regards,
Hans
Originally Posted by mike_jaworski View Post
Andre and others,
Regards,
Mike J.
Solver files
case files
Mesh Image
masspec is offline   Reply With Quote
Old   June 18, 2010, 03:55
VdG
Vincent de Graaf
VdG is on a distinguished road
k is the ion mobility or electric mobility, which is defined by Vd=k*E. Vd is the drift velocity in m/s, k is the electric mobility and E the electric field strength. The drift velocity is the physical speed at which the charge carriers travel through the medium.
The unit of k is m^2/(Vs) which is equal to As^2/kg.
VdG is offline   Reply With Quote
Old   June 21, 2010, 11:36
Xingzhi You
Thanks a lot for your explanation. Then could you also tell me what does solve fvm::ddt(rho) + fvm::div(rhoFlux, rho) actually means?
Old   November 20, 2010, 08:12
Daniele
Daniele111 is on a distinguished road
Hi
I'm trying to use electrostaticFoam. I would use it to simulate an elctroforming cell to calculate Nickel deposit thikness. So I must calculate charge density on my cathode and from that I can obtain deposit thikness. But in electrostaticFoam I must impose rho on my cathode. Is this the correct way to solve my problem:
1) I Solve Laplace equation (I impose potential on my surface)
2) I compute electric field
3) I obtain charge density on my surface with Coulomb theorem:
It's correct?
Thanks
Daniele111 is offline   Reply With Quote
Old   November 14, 2015, 07:25
Default how to calculate charge density ?
  #17
Mieszko Młody
ziemowitzima is on a distinguished road
Dear Foamers,
I am trying to solve for electric potential inside the capacitor.
But how can I calculate the charge density at the boundary ?
Is the charge density zero, or non-zero value in between the capacitor plates ?
thanks
ZMM
ziemowitzima is offline   Reply With Quote
UDF-electric field Srinivas Fluent UDF and Scheme Programming 20 August 29, 2017 15:16
electric field Alexandra Mutzke CFX 6 November 1, 2012 13:50
Electric Field calculation JamesT Phoenics 5 May 31, 2007 04:44
electric field in star-cd yong Siemens 0 November 16, 2004 07:43
How to calculate grad Electric Potential? Miko CFX 5 October 14, 2003 09:02
