What 's different between the linearUpwind and LinearUpwindV ?
Hi everyone,
I have confused between "linearUpwind" and "linearUpwindV". I dont know that as using the "linearUpwindV", it is better than use "linearUpwind" ? Could help me the formula of "linearUpwindV" method ? The word "V" in linearUpwindV ", which is the vector ? Thanks Phuc. |
I don't know the exact formulation of the different schemes, but some of your questions are answered in the OF UserGuide:
http://cfd.direct/openfoam/user-guide/fvschemes/ |
From the user guide: ‘V’-schemes are specialised versions of schemes designed for vector fields. They differ from conventional schemes by calculating a single limiter which is applied to all components of the vectors, rather than calculating separate limiters for each component of the vector. The ‘V’-schemes’ single limiter is calculated based on the direction of most rapidly changing gradient, resulting in the strongest limiter being calculated which is most stable but arguably less accurate. |
