Home > Forums > OpenFOAM Running, Solving & CFD
Periodic BC for Heated 2D Rib Channel
Old   November 16, 2015, 09:24
Default Periodic BC for Heated 2D Rib Channel
hcl734 is on a distinguished road
I try to simulated a 2D channel with a rib and periodic boundary condtions. But I need to keep
I am using the cyclic boundary condition to couple inflow and outflow patch.
But since pressure drops and temperature rises from rib to rib I have to modify the inlet conditions to fit.
I would like to avoid modifying the solver, because I am not really familiar with the source code.
I found an option to keep my velocity (=mass flow, incompressible, same area, dm/dt = u*A*rho) constant using fvOptions.
pressureGradientExplicitSourceCoeffs
fieldNames (U);
Ubar ( 1 0 0 );
gradPini gradPini [0 2 -2 0 0] 0; // initial pressure gradient
flowDir (1 0 0); // flow direction
But I also need to add a constant term (dq/dt)/((dm/dt)*cp*L) to compensate for the energy added by the heated walls.
How can I do this in OpenFOAM?
My idea so far is to set <<scalarExplicitSource>> for energy equation to subtract the term mentioned above, but I am not sure how to do it.
Something like:
energySource
    type            scalarExplicitSource;
    active          true;
    timeStart       0.2; // What are those entries for?
    duration        2.0;
    selectionMode   points;
    points
//[all points???]
    scalarExplicitSourceCoeffs
        volumeMode      absolute;
        injectionRate
            T         -(dq/dt)/((dm/dt)*cp*L);
The idea of subtracting the source term I got from
Fully Developed Flow and Heat Transfer in Ducts Having Streamwise-Periodic Variations of Cross-Sectional Area. S. V. Patankar, C. H. Liu and E. M. Sparrow
http://heattransfer.asmedigitalcolle...icleid=1436662
Every advice is appreciated!
Best
hcl734 is offline   Reply With Quote
Old   January 26, 2016, 07:23
Chris Coutinho
cbcoutinho is on a distinguished road
Hello hcl734,
I am also working on streamwise-periodic flow with mass/heat transfer. I'm interested in implementing this in openFOAM, and it looks like you are working on this as well. Have you made any progress since you asked this question?
Cheers,
c
cbcoutinho is online now   Reply With Quote
Old   January 26, 2016, 08:13
Hello Chris,
pressureGradientExplicitSourceCoeffs works fine to set a constant mass flux.
And I implemented the heat source the way patankar suggests in the mentioned paper following this thread
http://www.cfd-online.com/Forums/ope...-transfer.html
It works for me on one grid (mass flow and temperature become constant) but fails at another which is strange and I don't understand yet.
I can share my calculations with you privately but can't publish them here, since they are part of my thesis, pn me.
Best
Hendrik
Thread Tools
Trackbacks are On
periodic channel flow roadRunner STAR-CCM+ 0 June 25, 2015 07:32
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
[ANSYS Meshing] Meshing a Periodic channel with high curvature 2D airfoil ergometer ANSYS Meshing & Geometry 4 February 22, 2012 10:13
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 18:46
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
