Dynamic Mesh issue when coupling OpenFOAM with FSI
Old   May 12, 2020, 06:19
Default Dynamic Mesh issue when coupling OpenFOAM with FSI
Conor
ConorMD is on a distinguished road
Hi there,
While trying to run a simple FSI model, coupling Openfoam with Calculix with preCICE, I am encountering a problem with the dynamic mesh.
I am modelling the deflections on a single foil of a VAWT and the model is simplified to contain only a single foil rotating around a center point.
I am using a solidBody solver to define the rotating motion and a Laplacian for the foil deflection.
Before trying with FSI, I modelled as CFD only and the mesh moved as intended i.e. sliding. However, when tried with the FSI settings enabled, the mesh does not slide. It stretches and contorts. See attached pics.
Does anyone have a solution for this?
FYI, Openfoam 7 now allows the coupling of multiple motion solvers.
Many thanks in advance,
Conor
My dynamicMeshDict:
dynamicFvMesh  dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
solvers
	Turbine
		solver solidBody;
		solidBodyCoeffs
   		 	cellZone        rotorVolume;
    			solidBodyMotionFunction  rotatingMotion;
    			rotatingMotionCoeffs
     			 origin		(0 0 0);
      			 axis		(0 0 -1);
     		 	 omega       5.625;
	Foil
		solver displacementLaplacian;
		displacementLaplacianCoeffs
   		diffusivity quadratic inverseDistance (foil1);
ConorMD is offline   Reply With Quote
calculix, fsi, precice
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
Postprocessing issue with dynamic mesh? ghost82 FLUENT 1 November 2, 2012 10:06
