rhoCentralFoam - kOmegaSST - Floating point exception
Hello everyone,
I don't really have a single question but I am faced with a simulation problem I haven't been able to solve, so I hope someone here can help me. I am no CFD expert but for my master thesis in mechanical engineering I have to simulate then build a linear aerospike nozzle to accelerate high pressure air to super sonic speed. For the simulation I created a mesh using gmsh, imported it to foam and I am using the rhoCentralFoam solver with the kOmega turbulence model. The simulation starts "fine" but crashes after 6 microseconds... The error log I get is this: Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? Here is a link to the whole simulation case. I copy/pasted the error log from the terminal at the end of the "Log" file. The "spike26deg_mm.geo" and "spike26deg_mm.msh" are respectively the geometry and mesh file from GMSH. I set a write frequency of 1e-06 second because I wanted to see what was "happening" before the crash of the simulation. https://www.dropbox.com/sh/qd2iz7ifd...GP8kYkcxa?dl=0 You should be able to run the sim just like I did and toy around with the initial and boundary conditions. The inlet pressure is pretty high (6 atmospheres) but that's not the problem since the same problem occurs with 2 atmospheres. If you want any more details, feel free to ask. I will post any breakthrought I get. Thanks! DGW |
did you solve the issure?
