adjusting fvSchemes and fvSolution to correct for drag discrepancy
Like Tree1Likes
  • 1 Post By HPE
Old   December 9, 2015, 14:42
Default adjusting fvSchemes and fvSolution to correct for drag discrepancy
sergiu tofanel is on a distinguished road
I am running a 2D airfoil simulation of a NACA23012 section using simpleFoam as a solver.
The CL vs alpha seems to be in the ballpark with experimental results, but the drag is way too high. I understand that this is a common problem with turbulence model simulations. Right now I am using the native OpenFOAM SpalartAllmaras turbulence model with the default parameters.
After browsing through several posts on the subject, I am led to believe that the adjustments to the drag solution can be made through the fvScheme and fvSolution files. However, I have no idea how to tweak them. Is there an online tutorial anywhere that can point me to a solution? If not, what is the best way to proceed in this situation?
sergiu tofanel is offline   Reply With Quote
Old   February 5, 2017, 07:54
elones is on a distinguished road
did you solve the problem?
elones is offline   Reply With Quote
Old   June 25, 2021, 10:44
Sakun
Sakun is on a distinguished road
im also stuck here
Sakun is offline   Reply With Quote
Old   June 26, 2021, 09:12
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
any chance for you all to share a minimal example or the full case, so that we can also try to test what is going on?
Sakun likes this.
HPE is offline   Reply With Quote
Old   June 28, 2021, 06:12
Default Files in the 0 folder
Sakun
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
INLET
type fixedValue;
value (50 0 0);
OUTLET
type freestreamVelocity;
freestreamValue $internalField;
AIRFOIL
type noSlip;
TOP
type symmetry;
BOTTOM
type symmetry;
frontAndBack
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 82714.29;
boundaryField
INLET
type zeroGradient;
OUTLET
type freestreamPressure;
AIRFOIL
type zeroGradient;
TOP
type symmetry;
BOTTOM
type symmetry;
frontAndBack
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.14;
boundaryField
INLET
type freestream;
freestreamValue uniform 0.14;
OUTLET
type freestream;
AIRFOIL
type nutUSpaldingWallFunction;
value uniform 0;
TOP
type symmetry;
BOTTOM
type symmetry;
frontAndBack
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object nuTilda;
boundaryField
INLET
type freestream;
OUTLET
type freestream;
AIRFOIL
type fixedValue;
value uniform 0;
TOP
type symmetry;
BOTTOM
type symmetry;
frontAndBack
type empty;
Old   June 28, 2021, 06:19
Default Files in the system folder
Sakun
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 200000;
deltaT 1;
writeControl timeStep;
writeInterval 5;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
forces
type forceCoeffs;
libs ("libforces.so");
writeInterval 1;
patches
AIRFOIL
log true;
rho rhoInf;
rhoInf 1;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 50;
lRef 1;
Aref 1;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-08;
relTol 0.1;
nuTilda
nSweeps 2;
tolerance 1e-08;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-5;
U 1e-5;
nuTilda 1e-5;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
nuTilda 0.7;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda);
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
Old   July 1, 2021, 16:04
HPE
HPE's Avatar
no, I meant by a minimal example that could be downloadable and executable easily and effortlessly. thanks.
crucial settings with respect to fvSchemes and fvSolution to achieve convergence canopus OpenFOAM Running, Solving & CFD 0 March 1, 2015 14:31
rhoSimpleFoam fvSchemes fvSolution and convergence problems inf.vish OpenFOAM Running, Solving & CFD 0 October 24, 2013 23:50
Errors on fvSolution and fvSchemes Grimoli OpenFOAM Pre-Processing 1 September 28, 2013 09:10
General help for fvSchemes and fvSolution settings harly OpenFOAM Running, Solving & CFD 4 September 7, 2009 10:31
