Home > Forums > OpenFOAM Running, Solving & CFD
yPlus value for a turbolent airfoil case
Old   December 21, 2015, 12:15
Default yPlus value for a turbolent airfoil case
Lorenzo
Lorenzo92 is on a distinguished road
I runned a case of an airfoil immersed in an incompressible flow with an angle of attack of 4 degree. My turbolence model is Spalart-Allmaras, my solver is simpleFoam.
At the end of the running I wanted to visualize the y+ values on the airfoil by running the application yPlusRas .
My questions are:
1) was it correct to use yPlusRas for displaying maximum y+ on the airfoil?( so far I know y+ is the height of the first cell center on the surface)
2) My result of maximum y+ (by running yPlusRas) on the airfoil is 478, does this make sense if the case Re was 6000000?
Personally I thought I had to create a finer grid around the airfoil otherwise I cannot catch sufficiently good the boundary layer with a so high y+.
Thanks
Lorenzo92 is offline   Reply With Quote
Old   December 21, 2015, 17:32
shereez234's Avatar
shereez
shereez234 is on a distinguished road
Originally Posted by Lorenzo92 View Post
My questions are:
Thanks
I have read in this forum that OpenFOAM yPlusRas is actually YStar and not actualy Y plus. With in my knowledge if you are using wall functions - Y plus has to be between 30 to 100. If you are resolving wall boundary then Y+ should be strictly 1 or lower, although some people use a value below 5 too. May be it will be a good idea to read the law of the wall on wiki
Regards
Shereez
shereez234 is offline   Reply With Quote
Old   December 22, 2015, 12:55
Lorenzo
So the result of running yPlusRAS is the maximum , the minimum and the averaged value of the height of the first cell center in y+ dimensionless unit. Is this the meaning of y*?
Old   December 22, 2015, 17:18
shereez234's Avatar
shereez
Y Plus is the First cell height normal to the wall. Y star is the length along the first cell ( parallell to the flow) I guess. I advise you to read on it, again.
Sorry for not being a great help.
Shereez
Old   December 25, 2015, 04:23
Lorenzo
Ok Thanks for your advice anyway !!
Thread Tools
Trackbacks are On
Ffd_control_point_2d feiyi SU2 1 July 16, 2015 14:58
Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Mesh Utilities 57 February 1, 2015 09:25
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Fluid structure analysis of 2D airfoil case ahsan_smme.nust@yahoo.com OpenFOAM 0 April 22, 2014 06:12
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
