December 29, 2015, 09:05 |
How to setup Opening BCs?
Pei-Ying Hsieh
Rep Power: 18 |
Dear OpenFOAMers,
In my flow domain, i have one inlet and one outlet. Actually, these are both openings. I have an impeller inside, so, whether it is an inlet or outlet depends on direction of impeller rotation. How to specify BC in this situation? Thanks! Pei-Ying |
January 6, 2016, 04:47 |
Not sure if it will work, but maybe you can use totalPressure for p combined with pressureInletOutletVelocity for U on both sides. Regards, Tom |
January 6, 2016, 07:40 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Tom,
Thanks for the reply! This is what I used: U inlet { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } -------------- p inlet { type totalPressure; p0 uniform 0; U U; phi phi; rho none; psi none; gamma 1; value uniform 0; } outlet { type totalPressure; p0 uniform 0; U U; phi phi; rho none; psi none; gamma 1; value uniform 0; } ----------------------- Laminar case seems to work fine. However, sometimes I got trouble with kOmegaSST model. But, that could be due to bad k/omega BCs/ICs. I am still learning turbulence modeling. Pei-Ying |
How to setup cyclic BCs in simpleFOAM | hhuang84 | OpenFOAM Running, Solving & CFD | 14 | December 8, 2016 11:39 |
Are extruded boundaries good practice for opening BCs as well? | J_Keel | CFX | 1 | March 5, 2015 21:20 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
'opening' type BCs with LES | KK | CFX | 4 | February 14, 2008 12:06 |
Opening Vs outlet BCs and temporary wall issue | Sam | CFX | 0 | January 16, 2008 18:59 |
