pressure initialization
Dear Foamers,
I'm simulating fluid flow and heat transfer in a channel using buoyantBuossinesqSimpleFoam. In normal geometry everything is OK, but when i use a converging channel geometry the calculations will not converge. Actually the pressure starts with a very high value (about 3 bar, when I expect the converged pressure at inlet to be about 3kPa !!). So it takes a lot of time to decrease. My pressure conditions are: Code:
internalField uniform 0; Thanks a lot hoseinhd |
hello,
i would recommend you check out the following links: http://www.cfd-online.com/Forums/ope...plication.html http://www.cfd-online.com/Forums/ope...letoutlet.html best regards |
