MPI run run fails of quadcore openfoam2.4
I am trying mpirun , decomposePar worked fine upon
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : decomposePar Date : Jan 25 2016 Time : 19:28:34 Host : "GEOSCIENCE-PC" PID : 20725 Case : /home/priya/OpenFOAM/priya-2.4.0/run/simulation nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod scotch Finished decomposition in 19.3 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 1532953 Number of faces shared with processor 1 = 6519 Number of faces shared with processor 2 = 1733 Number of faces shared with processor 3 = 4880 Number of processor patches = 3 Number of processor faces = 13132 Number of boundary faces = 330832 Processor 1 Number of cells = 1540649 Number of faces shared with processor 0 = 6519 Number of faces shared with processor 2 = 4783 Number of faces shared with processor 3 = 709 Number of processor patches = 3 Number of processor faces = 12011 Number of boundary faces = 333490 Processor 2 Number of cells = 1653908 Number of faces shared with processor 0 = 1733 Number of faces shared with processor 1 = 4783 Number of faces shared with processor 3 = 5770 Number of processor patches = 3 Number of processor faces = 12286 Number of boundary faces = 353823 Processor 3 Number of cells = 1604279 Number of faces shared with processor 0 = 4880 Number of faces shared with processor 1 = 709 Number of faces shared with processor 2 = 5770 Number of processor patches = 3 Number of processor faces = 11359 Number of boundary faces = 348006 Number of processor faces = 24394 Max number of cells = 1653908 (4.48282% above average 1.58295e+06) Max number of processor patches = 3 (0% above average 3) Max number of faces between processors = 13132 (7.66582% above average 12197) Time = 0 Processor 0: field transfer Processor 1: field transfer Processor 2: field transfer Processor 3: field transfer End. priya@GEOSCIENCE-PC:~/OpenFOAM/priya-2.4.0/run/simulation$ mpirun –np <nProcs> buoyantBoussinesqSimpleFoam -parallel >& log & [1] 20734 bash: nProcs: No such file or directory priya@GEOSCIENCE-PC:~/OpenFOAM/priya-2.4.0/run/simulation$ mpirun –np 4 buoyantBoussinesqSimpleFoam -parallel >& log & [2] 20735 [1] Exit 1 mpirun –np -parallel < nProcs > buoyantBoussinesqSimpleFoam &> log nothing seems to happen . I am using opefoam240 version. Any help will be appreciated Thanks :confused::confused: |
Your first command is wrong. The second command might have worked, but you need to post the contents of the log file.
log file
Thanks for the quick reply
sorry i forgot to post the log file ###### my command : mpirun –np 4 buoyantBoussinesqSimpleFoam -parallel >& log & ###### the log file -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not find an executable: Executable: –np Node: GEOSCIENCE-PC while attempting to start process rank 0. -------------------------------------------------------------------------- I tried to search if there are any another MPI process my the command update-alternatives --config mpirun There is only one alternative in link group mpirun (providing /usr/bin/mpirun): /usr/bin/mpirun.openmpi Nothing to configure. any clues ? |
I bet you copy and pasted that command. Type it in proper, and all will be good (i. e. I believe the hyphen is not what you think it is).
