thermophysicalProperties with temperature dependance
Like Tree2Likes
  • 1 Post By olivierG
  • 1 Post By hcl734
Old   December 14, 2015, 04:06
Default thermophysicalProperties with temperature dependance
hcl734 is on a distinguished road
Hi all,
is it possible to set upper and lower limits for let's say density when using a polynomial approach?
I want to establish something like that:
Density as a function of temperature
rho_min: 1000
T < 240: 1100
T>240 : C1* T^2 + C2 *T + C3
It would also be possible to use step functions, if available.
Best
hcl734 is offline   Reply With Quote
Old   December 14, 2015, 04:34
Olivier
olivierG is on a distinguished road
hello,
This is not a feature in OF, but it's easy to add this : check how to modify the polynomial density, and add your limiter.
Take a loot at :http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf
This is for viscosity, but do the same for density...
The basic step are:
1) copy $FOAM_SRC/thermophysicalModels/specie/equationOfState/icoPolynomial/ where you want.
2) rename all "icoPolynomial" by what you want like "icoLimitPolynomail"(file name AND inside !)
3) modify in file to add what you want
4) add a make file (make sur lib will be in FOAM_USER_LIBBIN)
4) compile (wmake) and use it ! (do not forget the libname in you controlDict)
regards,
olivier
olivierG is offline   Reply With Quote
Old   December 14, 2015, 05:00
Ok found the solution
Use icoPolynomial for density as explained here http://cfd.direct/openfoam/user-guide/thermophysical/
and set the upper and lower limits for rho in the fvSolution
Old   December 14, 2015, 06:23
Thanks for showing me that paper, but to be honest I'm not very familiar with OF programming and I found this simple solution for density which works good for me.
BUT I want to do the same thing for heat capacit in chtMultiRegionSimpleFoam-solver.
For density the feature is implemented in the pressure equation as
rho = thermo.rho();
rho = max(rho, rhoMin[i]);
rho = min(rho, rhoMax[i]);
rho.relax();
And an entry in createFluidsField.H
    PtrList<dimensionedScalar> CpMax(fluidRegions.size());
    PtrList<dimensionedScalar> CpMin(fluidRegions.size());
        rhoMax.set(i, new dimensionedScalar(simpleDict.lookup("rhoMax")));
        rhoMin.set(i, new dimensionedScalar(simpleDict.lookup("rhoMin")));
And added in createFluidsField.H
        CpMax.set(i, new dimensionedScalar(simpleDict.lookup("CpMax")));
        CpMin.set(i, new dimensionedScalar(simpleDict.lookup("CpMin")));
But when I take a look at the EEqn.H
    volScalarField& he = thermo.he();
    fvScalarMatrix EEqn
        fvm::div(phi, he)
            he.name() == "e"
          ? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho))
          : fvc::div(phi, volScalarField("K", 0.5*magSqr(U)))
      - fvm::laplacian(turb.alphaEff(), he)
        rad.Sh(thermo)
      + fvOptions(rho, he)
    EEqn.relax();
    fvOptions.constrain(EEqn);
    EEqn.solve();
    fvOptions.correct(he);
    thermo.correct();
    rad.correct();
    Info<< "Min/max T:" << min(thermo.T()).value() << ' '
        << max(thermo.T()).value() << endl;
I can't even see where they are using specific heat capacity?
Could you help me with this one?
It would also be nice to write the Cp-field while solving to check whether it's correct or not.
Old   December 14, 2015, 07:42
Default Viscosity depending on temperature exponentially
2) Question
Is it also possible to set an exponential dependance between viscosity and temperature?
Something like:
(C1 + C2*exp(-(T-Tref)/C5) + C3*exp(-(T-Tref)/C6) + C4*exp(-(T-Tref)/C7)
Old   December 14, 2015, 08:15
Olivier
hello,
You are wrong about the limit in fvSolution => this bound rho, but NOT in a conservative way. This is only for stability purpose. You should use a correct model for density.
About 1°): Cp is inside alphaEff() ( ~ something like k/Cp + kt/Cp)
You can use polynomal for Cp => use janaf model
About 2°) by defaut, OF has only Sutherland viscosity(T) for gas. Take a look at the link i give you: this is how to add a custom viscosity.
BTW, you should not be afraid about coding with OF: this is the way do do.
regards,
olivier
Old   December 14, 2015, 11:44
Thanks for your advice, I followed the tutorial you showed me for implementing a temperature dependent viscosity, but this tutorial is only for incompressible flow using a viscosityProperties dictionary. But I want to calculate compressible using thermophysicalProperties.
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
with chtMultiRegionSimpleFoam
When I look at heRhoThermo.C
#include "heRhoThermo.H"
// * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
template<class BasicPsiThermo, class MixtureType>
void Foam::heRhoThermo<BasicPsiThermo, MixtureType>::calculate()
    const scalarField& hCells = this->he().internalField();
    const scalarField& pCells = this->p_.internalField();
    scalarField& TCells = this->T_.internalField();
    scalarField& psiCells = this->psi_.internalField();
    scalarField& rhoCells = this->rho_.internalField();
    scalarField& muCells = this->mu_.internalField();
    scalarField& alphaCells = this->alpha_.internalField();
    forAll(TCells, celli)
        const typename MixtureType::thermoType& mixture_ =
            this->cellMixture(celli);
        TCells[celli] = mixture_.THE
            hCells[celli],
            pCells[celli],
            TCells[celli]
        psiCells[celli] = mixture_.psi(pCells[celli], TCells[celli]);
        rhoCells[celli] = mixture_.rho(pCells[celli], TCells[celli]);
        muCells[celli] = mixture_.mu(pCells[celli], TCells[celli]);
        alphaCells[celli] = mixture_.alphah(pCells[celli], TCells[celli]);
    forAll(this->T_.boundaryField(), patchi)
        fvPatchScalarField& pp = this->p_.boundaryField()[patchi];
        fvPatchScalarField& pT = this->T_.boundaryField()[patchi];
        fvPatchScalarField& ppsi = this->psi_.boundaryField()[patchi];
        fvPatchScalarField& prho = this->rho_.boundaryField()[patchi];
        fvPatchScalarField& ph = this->he().boundaryField()[patchi];
        fvPatchScalarField& pmu = this->mu_.boundaryField()[patchi];
        fvPatchScalarField& palpha = this->alpha_.boundaryField()[patchi];
        if (pT.fixesValue())
            forAll(pT, facei)
                    this->patchFaceMixture(patchi, facei);
                ph[facei] = mixture_.HE(pp[facei], pT[facei]);
                ppsi[facei] = mixture_.psi(pp[facei], pT[facei]);
                prho[facei] = mixture_.rho(pp[facei], pT[facei]);
                pmu[facei] = mixture_.mu(pp[facei], pT[facei]);
                palpha[facei] = mixture_.alphah(pp[facei], pT[facei]);
        else
            forAll(pT, facei)
                pT[facei] = mixture_.THE(ph[facei], pp[facei], pT[facei]);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::heRhoThermo<BasicPsiThermo, MixtureType>::heRhoThermo
    const fvMesh& mesh,
    const word& phaseName
    heThermo<BasicPsiThermo, MixtureType>(mesh, phaseName)
    calculate();
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::heRhoThermo<BasicPsiThermo, MixtureType>::~heRhoThermo()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::heRhoThermo<BasicPsiThermo, MixtureType>::correct()
    if (debug)
        Info<< "entering heRhoThermo<MixtureType>::correct()" << endl;
    calculate();
    if (debug)
        Info<< "exiting heRhoThermo<MixtureType>::correct()" << endl;
I can't see much resemblance between this and the viscosityModel files.
Where should I start when modifying the compressible case?
I mean basically I only need an exponential function for defining mu and I need to know how to write the transportProperties as fields.
Thx again for your help!
Old   December 15, 2015, 03:21
Olivier
hello,
You should add a custom thermo model.
Check this : http://www.cfd-online.com/Forums/ope...tml#post451937
regards,
olivier
wayne14 likes this.
Old   December 19, 2015, 13:14
Ok I checked the post you recommended to me and I am trying to get into programming with OpenFoam.
But since this is quite tedious I am wondering whether it is possible to define a kind of lookup table for a thermophysical propertie in OpenFoam where I can put some data points (calculated externally) and OpenFoam does linear interpolation between those.
I hope you get my idea.
Old   February 12, 2016, 07:13
Didn't checked it but for everybody coming after me
This gives you the possibility to assign exponential terms
https://github.com/OpenFOAM/OpenFOAM...1ec9af6f399210
SamZar likes this.
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 11:43
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 04:56
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 06:08
where is the calculation of the temperature field Tobi OpenFOAM 1 July 30, 2012 10:40
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
