February 11, 2016, 02:02 |
BC conditions (suck the flow at the outlet)
Christof Schmidt
Rep Power: 10 |
Good morning everybody,
I have a question regarding boundary conditions. I want to suck a flow from the outlet. Normally you set p=0 at the outlet and a velocity at the inlet. But that means that you push the flow into let´s say a pipe. If you want the flow to be sucked from the outlet you actually have to switch the BC. I know that it´s not possible but is there any way that you can suck the flow? And in addition does anyone know why it´s not possible to set p=0 at the inlet and the velocity at the outlet? Regards Christof |
February 11, 2016, 02:57 |
Rep Power: 12 |
Hello Christoph,
it is possible to set the BCs for the velocity at the inlet as zeroGradient and outlet as fixedValue and for the pressure inverse. (I use this BCs in some cases without problems) It is also possible to set a negative pressuregradient from inlet to outlet to simulate suction. You have to look that you do not overdetermine your system by setting fixedValues for U and for p |
February 11, 2016, 04:54 |
Joachim Herb
Rep Power: 21 |
Perhaps you can use the fixedMean boundary conditions for the velocity at the inlet with a vector pointing out of your flow domain.
https://github.com/OpenFOAM/OpenFOAM...FvPatchField.H This avoids an non-physical jump in the velocity field at your "inlet" because it allows a flow profile on the boundary similar to the flow profile inside your flow domain. |
August 31, 2016, 23:28 |
#4 | |
Ping Chang
Rep Power: 10 |
Have you found the answer to your question? I want to simulate an exhaust ventilation system. The air will be sucked from the outlet. Which BC should I use? Kind Regards. Ping |
September 2, 2016, 16:55 |
Chris L
Rep Power: 13 |
Why does a negative velocity BC not work for this problem?
If I have a column, with an inlet at the bottom and outlet at the top. I can set suction by the following BC. outlet: U = -1 m/s P=0 inlet: U = zeroGradient P=zeroGradient or I can set a dP. outlet: U = zeroGradient m/s P=0 inlet: U = zeroGradient P=2 kPa Can you clarify what the problem is. Chris |
October 5, 2016, 04:21 |
#6 | |
Ping Chang
Rep Power: 10 |
This should be work, you can set the pressure difference at inlet or outlet. And set velocity BC as pressureinletoutletveloctiy. It should be work. Kind regards, Ping |
October 5, 2016, 10:56 |
codedFixedValue BC
Sachin
Rep Power: 9 |
I am using codedFixedValue bc for implementing ΔV=0 ;where V=x2+y2+z2
my boundarycondition at 0/phi is: inlet { type codedFixedValue; value uniform 0; redirectType velocitySquareInlet; code #{ const fvPatch& boundaryPatch = patch(); const vectorField& Cf = boundaryPatch.Cf(); scalarField& field = *this; forAll(Cf, faceI) { ( (Cf[faceI].x()=0) && (Cf[faceI].y()=0) && (Cf[faceI].z()=0) ) { field[faceI] = ((Cf[faceI].x()*Cf[faceI].x()) +(Cf[faceI].y()*Cf[faceI].y()) +(Cf[faceI].z()*Cf[faceI].z())); } } #}; and I will have following error at terminal Using dynamicCode for patch inlet on field phi at line 25 in "/home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet" Creating new library in "dynamicCode/velocitySquareInlet/platforms/linux64GccDPInt32Opt/lib/libvelocitySquareInlet_f5eecc7ba736b15b9d60f3aa108 fc0cf20d513de.so" Invoking "wmake -s libso /home/sachin/OpenFOAM/Conduction/charge-20/dynamicCode/velocitySquareInlet" wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file fixedValueFvPatchFieldTemplate.C /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet: In member function ‘virtual void Foam::velocitySquareInletFixedValueFvPatchScalarFi eld::updateCoeffs()’: /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet:39:35: error: assignment of read-only location ‘(&(& Cf)->Foam::Field<Foam::Vector<double> >::<anonymous>.Foam::List<Foam::Vector<double> >::<anonymous>.Foam::UList<T>:perator[]<Foam::Vector<double> >(faceI))->Foam::Vector<Cmpt>::x<double>()’ /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet:40:35: error: assignment of read-only location ‘(&(& Cf)->Foam::Field<Foam::Vector<double> >::<anonymous>.Foam::List<Foam::Vector<double> >::<anonymous>.Foam::UList<T>:perator[]<Foam::Vector<double> >(faceI))->Foam::Vector<Cmpt>::y<double>()’ /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet:41:35: error: assignment of read-only location ‘(&(& Cf)->Foam::Field<Foam::Vector<double> >::<anonymous>.Foam::List<Foam::Vector<double> >::<anonymous>.Foam::UList<T>:perator[]<Foam::Vector<double> >(faceI))->Foam::Vector<Cmpt>::z<double>()’ /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet:43:17: error: expected ‘;’ before ‘{’ token /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet:34:26: warning: unused variable ‘field’ [-Wunused-variable] /opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/fixedValueFvPatchFieldTemplate.o' failed make: *** [Make/linux64GccDPInt32Opt/fixedValueFvPatchFieldTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/velocitySquareInlet/platforms/linux64GccDPInt32Opt/lib/libvelocitySquareInlet_f5eecc7ba736b15b9d60f3aa108 fc0cf20d513de.so" file: /home/sachin/OpenFOAM/Conduction/charge-20/0/phi.boundaryField.inlet from line 25 to line 30. From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const in file db/dynamicLibrary/codedBase/codedBase.C at line 206. FOAM exiting Does anyone know the solution? Thanks in advance!!!!! |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Temperature at a velocity/mass flow outlet | saisanthoshm88 | CFX | 1 | July 8, 2014 18:35 |
Outlet BC for disturbed Poiseuille flow | murx | CFX | 10 | February 22, 2012 13:55 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
