February 14, 2016, 07:48 |
Monitoring Boundary Movement
Hello guys,
I am having a 6DOF moving mesh problem in which a boundary moves due to the fluid forces exerted on it. Problem seems to be solved fine and without any problems, but now I wonder how it is possible to know the position of a point (on a boundary) with time? Is there any function object to do that? Regards.
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
February 14, 2016, 13:31 |
I found and explained a solution in here:
http://www.cfd-online.com/Forums/ope...tml#post585127
6dof, boundary probe, function object, mesh motion, monitoring |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
