Problems with heat transfer in a cylinder in Cartesian coordinate using laplacianFoam |
Amir
Rep Power: 12 ![]() |
Hi
I want to model a simple transient heat conduction in a solid object with source term. I used laplacianfoam, but I found that it solves in steady state condition. I put a heat flux on one end of the objects and other sides remained isolated (dT/dx=0). after a while I saw that there is no change in the thermal distribution inside the object . I tried to add while (runtime.loop()) {} instead of the while (simple.loop()) {} but it still doesn't work. I was wondering if you help me in this issue: Code:
int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" simpleControl simple(mesh); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nCalculating temperature distribution\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; while (simple.correctNonOrthogonal()) { solve ( fvm::ddt(cp,T) - fvm::laplacian(lambda/rho, T) -(latent)*fvc::ddt(gS) ); } #include "calcgS.H" #include "write.H" Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } Last edited by wyldckat; February 21, 2016 at 14:32. Reason: Added [CODE][/CODE] markers |
Amir
Hi
I simulated heat transfer in a cylinder in Cartesian coordinate in OpenFoam using LaplacianFoam. The initial temperature of the cylinder is 1500c, top and bottom of the cylinder set zeroGrarient (dT/dx=0) and cylinder sides has dT/dx = -2000. Total simulation run is 20000sec. The purpose is to model a simple transient heat transfer. In this type of problem I expected to see the temperature decrease in every time steps. My problem is that after around 4000sec the temperature distribution in the cylinder doesn’t change, but openFoam continue running without any error.this problem happen even when I set a fixed boundary condition on the cylinder sides like Tside=1000c. when I simulated heat transfer in a cube which right face has a flux but other faces are dT/dx=0 the simulation run well and temperature decreases until the end of simulation. I don't know why this happen when I use cylinder. I attached solver that I edited (testlaplacian) with 0-constant-system folders. Last edited by ghorob; February 10, 2016 at 15:58. |
#3 | |
Amir
Display Modes | |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
CFX conjugate heat transfer problems | dingsheng1206 | CFX | 7 | February 13, 2014 13:29 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Local heat transfer coefficient around a cylinder | dal_fry | FLUENT | 2 | March 29, 2013 13:35 |
