Courant number of 40 but still produce accurate results. How?
Old   February 20, 2016, 14:26
Default Courant number of 40 but still produce accurate results. How?
Skh
Sia
Skh is on a distinguished road
Hello everyone,
I'm running a 2D Lid-driven cavity flow of Re=1000 at mesh size of 100x100x1. The solver used in this case is pimpleFoam. I set the maxCo to 40 and the results are fast and very accurate when compared to the results from Ghia et al. (1982). I'm struggling to find the reasoning behind this? I thought Courant number should be less or equal to one. However, for my case, it can go up to 40 and still produce an accurate result. I have attached the links to the files of the case. Thank you all for reading this. I hope somebody can help clarify this situation over here. Thanks
Skh is offline   Reply With Quote
Old   February 22, 2016, 14:29
Skh
Sia
http://www.cfd-online.com/Forums/star-ccm/111278-courant-number-cfl-number.html
Last edited by Skh; February 22, 2016 at 14:30. Reason: Sorry for repeating discussion.
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
