why there is no iteration for velocity U in reacting foam? |
February 20, 2016, 06:59 |
Prasanna Welahettige
Rep Power: 10 |
Hai,
I have a question, why there is no iteration for velocity in reacting foam. I'm runing the openfoam model with reacting foam for mixing of two gases without reaction. But unfortunatly, I can not see the iteration for U. As example, diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for CH4, Initial residual = 9.70475e-05, Final residual = 1.12659e-10, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 7.69168e-05, Final residual = 1.13125e-09, No Iterations 1 min/max(T) = 284.895, 475.458 DICPCG: Solving for p, Initial residual = 5.49665e-05, Final residual = 7.40307e-10, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.2506e-06, global = 4.28088e-07, cumulative = 0.000749189 DICPCG: Solving for p, Initial residual = 9.12151e-09, Final residual = 9.12151e-09, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.25063e-06, global = 4.28091e-07, cumulative = 0.000749617 ExecutionTime = 2727.74 s ClockTime = 2729 s Here it has calculated for P,h,and CH4 only. But in icoFom model it shows iteration for Velocity. example, smoothSolver: Solving for Ux, Initial residual = 2.32737e-07, Final residual = 2.32737e-07, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 5.07002e-07, Final residual = 5.07002e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 1.0281e-06, Final residual = 2.77237e-07, No Iterations 1 time step continuity errors : sum local = 4.0374e-09, global = -9.0204e-19, cumulative = -2.44407e-18 DICPCG: Solving for p, Initial residual = 5.31987e-07, Final residual = 5.31987e-07, No Iterations 0 time step continuity errors : sum local = 6.12557e-09, global = -3.93738e-20, cumulative = -2.48344e-18 ExecutionTime = 0.17 s ClockTime = 1 s What is the reason for it? Anyone know the reason for this difference ? Best Regards, Prasanna. |
February 21, 2016, 14:01 |
Dongyue Li
Rep Power: 17 |
Hi Prasanna,
Sometimes you dont need to solve velocity, but u must construct velocity matrix. Check it in your pimple solution (fvSolution), I estimate the momentum predictor is switched off. Best,
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
February 22, 2016, 02:51 |
Maximum number of iterations exceeded
Rep Power: 10 |
Hai Dongyue Li,
Thank you for the comment. Your guess is exactly correct. I have switch off momentumpredictor . I will show it bellow , just to if someone else need reactingFoam > fvSolution >PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; } I have another question with runing in reactingFoam. It gives me following error, This error comes after few iterations. --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:? #3 Foam::hePsiThermo<Foam:siReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::co nstTransport<Foam::species::thermo<Foam::hConstThe rmo<Foam:erfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam:siReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::co nstTransport<Foam::species::thermo<Foam::hConstThe rmo<Foam:erfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Aborted (core dumped) meeseeks@meeseeks-Precision-Tower-7810:~/prasa/run16_withstatic_mixer$ paraview ERROR: In /build/buildd/paraview-4.0.1/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 8464 vtkPOpenFOAMReader (0x4105ab0): /home/meeseeks/prasa/run16_withstatic_mixer/system/fvSolution contains no timestep data. Do you have a idea about this ? Regards, Prasanna. |
February 22, 2016, 03:35 |
Dongyue Li
Rep Power: 17 |
Well, it just blow up. I have no idea about this. If switching off momentum predictor makes it blowing up, just switch it off. In some cases momentum predictor is not good for convergence.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
