IcoFoam continuity error in 2D transient simulation |
October 27, 2005, 12:09 |
I am running a basic test case
a
Rep Power: 17 |
I am running a basic test case using icoFoam. I defined a 2D channel with two walls, an inlet, and an outlet. The walls have a no-slip boundary condition U=uniform(0 0 0). The inlet has a boundary condition of U=uniform(1 0 0) which causes flow into the channel with a uniform velocity profile. The outlet BC is of type zeroGradient for U. All pressure boundaries are of type zeroGradient. This setup produces the following error:
Reading/calculating face flux field phi Starting time loop Time = 0.001 Mean and max Courant Numbers = 0 0.1 BICCG: Solving for Ux, Initial residual = 1, Final residual = 9.49086e-09, No Iterations 1 --> FOAM FATAL ERROR : Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file adjustPhi/adjustPhi.C at line 108. FOAM exiting If I set one wall b.c. OR the internalField to U=uniform(0.00001 0 0) then the expected parabolic velocity profile develops. Reducing the time step does not help. Can someone please explain why this is happening, and how to set it up correctly? |
October 27, 2005, 12:30 |
Have a look at your boundary c
Hrvoje Jasak
Rep Power: 33 |
Have a look at your boundary conditions on the velocity. In FOAM, we typically use fixed value U and zero gradient pressure at the inlet and fixed pressure and zero gradient U at the outlet. There is an option of using zero gradient on both p and U at the outlet, but then the code needs to adjust the outlet velocities in order to achieve global continuity. The message says it cannot do that for some reason.
Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 27, 2005, 23:49 |
Oops. I thought I had set the
a
Rep Power: 17 |
Oops. I thought I had set the output pressure to zero instead of zeroGradient, but after checking I realize that it was in fact zeroGradient. No wonder it wasn't working. Thanks for the tip. I'll post my results as a tutorial sometime.
March 27, 2012, 01:42 |
Thank You
cfdkid
Rep Power: 17 |
Hello Hrv,
Your comments helped a lot. regards, cfdkid |
September 24, 2013, 17:11 |
Rep Power: 15 |
great help. Also valid for SimpleFoam!!!
thanks a lot!!! |
November 15, 2014, 23:06 |
Continuity error in sloshingtank2d
#6 | |
musaddeque hossein
Rep Power: 18 |
I am running sloshingTank2D in interDYMFoam. Tank dimensions in the y direction (horizontal) is 11 meters; vertical 7 meters. Water depth is 4.4 meters. There is no inflow or outflow. However I get a error message as follows: [5] --> FOAM FATAL ERROR: [5] Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 4.06534e-16 Specified mass inflow : 5.66242e-19 Specified mass outflow : 8.26281e-19 Adjustable mass outflow : 0 [5] [5] [5] From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p [5] in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. [5] FOAM parallel run exiting [5] [4] [4] [4] --> FOAM FATAL ERROR: [4] Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 4.06534e-16 Specified mass inflow : 5.66242e-19 Specified mass outflow : 8.26281e-19 Adjustable mass outflow : 0 Can any tell me why I am getting this error? Thankyou. |
February 20, 2015, 02:22 |
Your error says that your inflow and your outflow is not the same. Look at your BC, they need to deal with the same amount of flux comming in and out.
February 20, 2015, 08:09 |
musaddeque hossein
Rep Power: 18 |
Thankyou for your response. I am simulating a tank in sloshingtank2d. What is realized is that this error was given due to a run time error. It is one of those cases where a run time error creates other cascading errors.
February 20, 2015, 08:20 |
#9 |
Dear, musahossein, do you have expirience in snappyHexMesh? If you have and are willing to look on a problem I would appriciate.
here is a link: http://www.cfd-online.com/Forums/ope...esh-walls.html cheers Raitis. |
February 20, 2015, 09:30 |
#10 | |
musaddeque hossein
Rep Power: 18 |
February 20, 2015, 09:59 |
#11 |
No worries.
Yes I undarstand that it is a way, but this time I need to do with this method. |
May 5, 2015, 11:43 |
#12 | |
Chen Linya
Rep Power: 11 |
I am expirienceing this problem,can you tell me the details about the run time error? |
May 5, 2015, 13:48 |
#13 | |
musaddeque hossein
Rep Power: 18 |
Also, are you running the latest version of OpenFOAM? From what I hear, it is more robust and handles these types of errors better. |
May 6, 2015, 01:25 |
#14 | |
Chen Linya
Rep Power: 11 |
I use the foam-extend-3.1,i want to combine the icoFsiFoam and interFoam to a interFsiFoam to couple with multiphase fluid-struction interaction problem(dambreak with a elastic baffle),and the error occured in first interation(and i guess) due to the fluid mesh moving.the dynamicMeshDict as follow: dynamicFvMesh dynamicMotionSolverFvMesh; twoDMotion yes; solver laplace; diffusivity quadratic; frozenDiffusion on; distancePatches(consoleFluid); |
May 7, 2015, 10:04 |
#15 |
musaddeque hossein
Rep Power: 18 |
I would suggest that you check your mesh, Start with checkmesh or (CheckMesh?) command once you have run blockMesh, to make sure OpenFOAM is ok with your aspect ratio.
Once you have established that it is not a aspect ratio problem, it is more likely how you are communicating the input data to OpenFOAM, or how you have set up the problem. Check those in a systematic manner. |
June 29, 2016, 10:39 |
#16 |
Asmaa
Rep Power: 10 |
I am simulating a mixing tank using multiphaseEulerFoam and I get this error message --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. I understand that it's from my BC, because I am using movingwall, so how can I set movingWall without having problems when I run the simulation? |
Von Karman street simulation with icoFoam | agrewal | OpenFOAM Running, Solving & CFD | 3 | February 9, 2008 17:12 |
Transient simulation Error information | Li | CFX | 0 | July 25, 2007 11:27 |
Transient simulation error | sree | CFX | 0 | November 2, 2005 10:03 |
Transient simulation error on start - | Korsh Mik | CFX | 1 | November 2, 2005 09:08 |
MRF simulation : continuity residual high as 0.4 | guru | FLUENT | 2 | February 7, 2005 09:33 |
