dynamicFvRefineMesh increases mesh non-orthogonality |
March 4, 2016, 13:29 |
Aditya Raman
Rep Power: 10 |
A long time lurker of this community, all my questions and issues were already solved by searching through this vast community ! I however have an issue that seems rather strange to me, so i was hoping you guys might help shed some light on this.
I am using a solver modified from pimpleDyMFoam to solve for passive scalar in the domain (it's a generic jet in crossflow problem) and using the dynamicFvRefineMesh to adapt the mesh to the vorticity magnitude. I used snappyHexMesh to generate the mesh. Here's the checkMesh results before starting the simulation:- Code:
Checking geometry... Overall domain bounding box (-0.03999999911 -0.02000255726 -0.3199999928) (0.2800000012 0.6399999857 0.3199999928) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-6.060718881e-14 1.291685911e-13 -2.303600518e-14) OK. Max cell openness = 5.400546049e-16 OK. Max aspect ratio = 24.14037861 OK. Minimum face area = 2.946087816e-09. Maximum face area = 0.0005165836257. Face area magnitudes OK. Min volume = 6.73982538e-13. Max volume = 1.175411952e-05. Total volume = 0.1310735564. Cell volumes OK. Mesh non-orthogonality Max: 64.79991779 average: 3.047065537 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.625462248 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 1.592653958e-05 0.02254557784 OK. *There are 92 faces with concave angles between consecutive edges. Max concave angle = 32.20257068 degrees. <<Writing 92 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.9117923961 average = 0.9999967098 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.001550385698 average: 6.801338517 Cell determinant check OK. ***Concave cells (using face planes) found, number of cells: 8402 <<Writing 8402 concave cells to set concaveCells Face interpolation weight : minimum: 0.03132999624 average: 0.4940655109 ***Faces with small interpolation weight (< 0.05) found, number of faces: 16 <<Writing 16 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.02173256797 average: 0.9794945019 Face volume ratio check OK. Failed 2 mesh checks. Code:
Checking geometry... Overall domain bounding box (-0.03999999911 -0.02000255726 -0.3199999928) (0.2800000012 0.6399999857 0.3199999928) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.020092674e-14 1.188726109e-13 -3.679502457e-14) OK. Max cell openness = 5.508432446e-16 OK. Max aspect ratio = 24.14037859 OK. Minimum face area = 7.546356897e-10. Maximum face area = 0.0005165836257. Face area magnitudes OK. Min volume = 1.232590365e-13. Max volume = 1.175411952e-05. Total volume = 0.1310735564. Cell volumes OK. Mesh non-orthogonality Max: 83.10049294 average: 4.794040349 *Number of severely non-orthogonal (> 70 degrees) faces: 44534. Non-orthogonality check OK. <<Writing 44534 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 1.893790671 OK. Coupled point location match (average 0) OK. ***Error in face tets: 40 faces with low quality or negative volume decomposition tets. <<Writing 40 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces Min/max edge length = 7.963269329e-06 0.02254557784 OK. *There are 100 faces with concave angles between consecutive edges. Max concave angle = 32.20257105 degrees. <<Writing 100 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.9015482556 average = 0.9999956346 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.002197372934 average: 8.207526567 Cell determinant check OK. ***Concave cells (using face planes) found, number of cells: 25810 <<Writing 25810 concave cells to set concaveCells Face interpolation weight : minimum: 0.0144084187 average: 0.4932446695 ***Faces with small interpolation weight (< 0.05) found, number of faces: 56 <<Writing 56 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.006704875336 average: 0.9756846993 ***Faces with small volume ratio (< 0.01) found, number of faces: 2138 <<Writing 2138 faces with low volume ratio cells to set lowVolRatioFaces Failed 4 mesh checks. |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[snappyHexMesh] non orthogonality of mesh due to curvature of nsurfaceLayer in snappyHexMesh | ali_atrian | OpenFOAM Meshing & Mesh Conversion | 0 | May 27, 2015 17:09 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
