March 4, 2016, 20:07 |
Running of PotentialFoam with shiphull
Xin Ren
Rep Power: 10 |
Hi all, I am a new user to using OpenFOAM, and I am currently trying out potentialFoam with a shiphull application.
Below is the file for blockMesh /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1000; vertices ( (-50 -500 -150) //node 0 layer 1 (300 -500 -150) (300 23.195 -150) (-50 23.195 -150) //node 3 (-50 -500 -70) //node 4 layer 2 (300 -500 -70) (300 23.195 -70) (-50 23.195 -70) //node 7 (-50 -500 10) //node 8 layer 3 (300 -500 10) (300 23.195 10) (-50 23.195 10) //node 11 (-50 -500 15) //node 12 layer 4 (300 -500 15) (300 23.195 15) (-50 23.195 15) //node 15 (-50 -500 20) //node 16 layer 5 (300 -500 20) (300 23.195 20) (-50 23.195 20) //node 19 (-50 -500 90) //node 20 layer 6 (300 -500 90) (300 23.195 90) (-50 23.195 90) //node 23 (-50 -500 150) //node 24 layer 7 (300 -500 150) (300 23.195 150) (-50 23.195 150) //node 27 ); blocks ( hex (0 1 2 3 4 5 6 7) (350 524 220) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (350 524 80) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (350 524 25) simpleGrading (1 1 1) hex (12 13 14 15 16 17 18 19) (350 524 35) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (350 524 110) simpleGrading (1 1 1) hex (20 21 22 23 24 25 26 27) (350 524 240) simpleGrading (1 1 1) ); edges ( ); boundary ( atmosphere { type patch; faces ( (24 25 26 27) ); } inlet { type patch; faces ( (1 2 6 5) (5 6 10 9) (9 10 14 13) (13 14 18 17) (17 18 22 21) (21 22 26 25) ); } outlet { type patch; faces ( (0 4 7 3) (4 8 11 7) (8 12 15 11) (12 16 19 15) (16 20 23 19) (20 24 27 23) ); } bottom { type symmetryPlane; faces ( (0 3 2 1) ); } side { type symmetryPlane; faces ( (0 1 5 4) (4 5 9 8) (8 9 13 12) (12 13 17 16) (16 17 21 20) (20 21 25 24) ); } midPlane { type symmetryPlane; faces ( (3 7 6 2) (7 11 10 6) (11 15 14 10) (15 19 18 14) (19 23 22 18) (23 27 26 22) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // This is done based on LTSInterFoam solver |
March 4, 2016, 20:09 |
Xin Ren
Rep Power: 10 |
I am able to run blockMesh command without any issue, however, as i am running -writePhi -writep, it states
-writePhi: command not found Anyone that can help me with this issue? |
March 5, 2016, 11:59 |
Alex
Rep Power: 12 |
I am not 100% sure what the writePhi writep command is supposed to do but in OF 3.0.1 which I am using you simply type potentialFoam to run it.
What version are you using? Have you included the setting for potentialFoam in your fvSolution? Cheers Alex |
March 5, 2016, 22:46 |
Xin Ren
Rep Power: 10 |
Hi Kina,
I am using version 2.4, but with 2.3.x files for running of potentialFoam. Yes, I did input potentialFoam in fvSolutions file. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { Phi { solver GAMG; smoother DIC; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; tolerance 1e-06; relTol 0.01; } p { $Phi; } } potentialFlow { nNonOrthogonalCorrectors 3; } // ************************************************** *********************** // |
March 6, 2016, 02:38 |
Alex
Rep Power: 12 |
So the command:
potentialFoam -writep |
March 6, 2016, 19:54 |
Xin Ren
Rep Power: 10 |
#!/bin/sh
cd ${0%/*} || exit 1 # Run from this directory # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions application=`getApplication` cp -r 0.org 0 > /dev/null 2>&1 runApplication blockMesh runApplication $application -writePhi -writep runApplication streamFunction # ----------------------------------------------------------------- end-of-file I ran blockMesh, then -writePhi -writep, and this is where I got stuck at |
potentialFoam not working properly | GAlava | OpenFOAM Running, Solving & CFD | 7 | March 9, 2021 11:34 |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 13:30 |
potentialFoam force calculation | TypeR | OpenFOAM Running, Solving & CFD | 0 | September 14, 2015 14:11 |
Unconsistent parallel jobs running time | arnaud6 | OpenFOAM Running, Solving & CFD | 4 | February 10, 2015 12:42 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
