Strange pressure/velocity fields using buoyantPimpleFoam |
August 25, 2020, 12:29 |
Liv Pontes
Hello Foamer,
I am studying the influences of the external flow of exhaustion fan in a helical condenser using bouyantPimpleFoam. My problem consists: - The domain is a "wind tunnel”; - The fan is rotating with 162 rad/s; - The velocity in the inlet is 1 m/s; - The condenser has a variation of temperature, but its internal flow is not analysed. The problem is my results seems strange, because p_rgh and U are not uniform as it should be and p has some kind of stain, as it can be seen in the pictures for the time 0.35s. Picture_p.JPG Picture_U.JPG Picture_prgh.JPG These are my checkMesh, fvSolution, fvSchemes and boundary conditions for p, p_rgh and U. checkMesh: Create time Checking geometry... Overall domain bounding box (-0.6624 -0.552 -0.552) (1.26835 0.552 0.552) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (8.72236e-17 -1.89034e-16 1.21992e-16) OK. Max cell openness = 3.28732e-16 OK. Max aspect ratio = 7.35925 OK. Minimum face area = 7.81001e-07. Maximum face area = 0.0149429. Face area magnitudes OK. Min volume = 3.39861e-10. Max volume = 0.000531389. Total volume = 2.35281. Cell volumes OK. Mesh non-orthogonality Max: 69.7345 average: 17.2367 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.4638 OK. Coupled point location match (average 0) OK. Mesh OK. End fvSolution: ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(U) cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwindV grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(meshPhi,p) Gauss linear; div(phi,h) Gauss upwind; div(phi,e) Gauss upwind; div(phi,R) Gauss upwind; div(phi,K) Gauss linear; div(phi,Ekp) Gauss linear; div(R) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } fvSolution: solvers { "rho.*" { solver PCG; preconditioner DIC; tolerance 0; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-8; relTol 0.01; } p_rghFinal { $p_rgh; relTol 0; } "pcorr.*" { solver GAMG; smoother DICGaussSeidel; cacheAgglomeration no; maxIter 50; tolerance 1e-2; relTol 0; } "(U|h|e|k|omega|R)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 0.1; } "(U|h|e|k|omega|R)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; } U: Uinlet (1 0 0); dimensions [0 1 -1 0 0 0 0]; internalField uniform (1 0 0); boundaryField { inlet { type fixedValue; value uniform $Uinlet; } outlet { type pressureInletOutletVelocity; value uniform $Uinlet; } wall { type noSlip; } fan { type movingWallVelocity; value uniform (0 0 0); } "wall_cond_.*" { type noSlip; } ami_2 { type cyclicAMI; value $internalField; } ami_1 { type cyclicAMI; value $internalField; } } p: dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { outlet { type calculated; value $internalField; } inlet { type calculated; value $internalField; } wall { type calculated; value $internalField; } fan { type calculated; value $internalField; } "wall_cond_.*" { type calculated; value $internalField; } ami_2 { type cyclicAMI; value $internalField; } ami_1 { type cyclicAMI; value $internalField; } } p_rgh: dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 0; boundaryField { outlet { type fixedValue; value uniform 0; } inlet { type fixedFluxPressure; value uniform 0; } wall { type fixedFluxPressure; value uniform 0; } fan { type fixedFluxPressure; value uniform 0; } "wall_cond_.*" { type fixedFluxPressure; value uniform 0; } ami_2 { type cyclicAMI; value $internalField; } ami_1 { type cyclicAMI; value $internalField; } } I don't know why this is happening and I hope that someone could help me. |
August 25, 2020, 23:13 |
Ardalan
Rep Power: 13 |
can you share your case?
That is hard to tell like this? |
Display Modes | |
Am getting very strange pressure/velocity problems at the inlet after a while | avc18 | OpenFOAM Running, Solving & CFD | 9 | July 27, 2019 10:29 |
multiphaseEulerFoam: efficient way of implementing fields for all phases | maybee | OpenFOAM Programming & Development | 0 | January 23, 2014 05:16 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 12:25 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 23:36 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 10:15 |
