Non-isothermal incompressible LES in OpenFOAM
Like Tree1Likes
  • 1 Post By itchy
Old   January 14, 2014, 10:22
Default Non-isothermal incompressible LES in OpenFOAM
Sagnik
sagnikmazumdar is on a distinguished road
I was wondering which solver should we use to simulate a 'Non-isothermal incompressible LES in OpenFOAM' without the boussinesq approximation. I understand there is a well laid out procedure for flows with 'boussinesq approximation':
http://openfoamwiki.net/index.php/Bu...sinesqPisoFoam
We would like to use temperature dependent fluid properties for the LES simulation (ideal gas for density of good enough). Any information would be of great help.
Thanks for all the help.
Sagnik
sagnikmazumdar is offline   Reply With Quote
Old   January 14, 2014, 11:34
Chris Sideroff
cnsidero is on a distinguished road
If you want temperature dependent fluid properties through ideal gas law, it will no longer be incompressible. The point of the Boussinesq approach is to avoid variable density (and the compressible formulation) and instead "model" density changes through a body force term dependent on temperature.
The rule of thumb for Boussinesq validity is \beta\Delta T << 1
Your alternative is to explore the buoyantPimpleFoam solver which has variable density but as I mentioned will be compressible.
Originally Posted by sagnikmazumdar View Post
Sagnik
cnsidero is offline   Reply With Quote
Old   January 14, 2014, 12:20
Sagnik
Yes, very true. I understand that you are suggesting 'buoyantPimpleFoam' solver. Would it be possible for you to suggest us a good reference work with OpenFOAM in this regard !
Thanks for all the help and inputs.
Sagnik
Old   January 14, 2014, 13:28
Chris Sideroff
If you check out the buoyantPimpleFoam source you will see it's already capable of using LES. Switching between RAS and LES is handled in the constant/turbulenceProperties dictionary. Then add/modify an constant/LESProperties dictionary to define the LES model you want to use.
Since it's compressible you may want to refer to one of the existing LES compressible tutorials for model and BC options.
Good luck
Old   December 5, 2014, 02:14
Florian Ries
itchy is on a distinguished road
Hi all,
just for better understanding:
if the density is only a function of temperature and composition, then the flow is incompressible but the density can change!!!! (with temperature and composition). In an compressible flow, the denisty is a function of pressure. If the Mach number is higer then lets say 0.3 , we have to care about the pressure.
The most people think that incompressible is if density do not change. This is wrong! This kind of flow is constant density flow.
In my opinion it is very confusing in OpenFoam, that some solvers are called compressible and incompressible. For example buoyantPimpleFoam can be used for compressible and incompressible flow. It depends on which equation of state you use in thermophysicalProperties dictionary. If you choose:
equationOfState incompressiblePerfectGas;
then the flow is incompressible. If you choose:
equationOfState perfectGas;
then the flow is compressible.
In both cases the density can change.
kind regards
Florian
ykanani likes this.
itchy is offline   Reply With Quote
Old   December 5, 2014, 02:19
Florian Ries
Hi drmarcoguevara,
bouyantPimpleFoam and bouyantSimpleFoam should be able to handle non-isothermal incompressible flow. But I am very intrested in the code you mentioned. Could you please upload the code in the forum??
Then we can verificate the code. This should be helpfull for you as well.
If this is impossible, could you please send me the code:
ries@ekt.tu-darmstadt.de
kind regards
Florian
Old   March 9, 2016, 03:41
Desanga
desanga is on a distinguished road
hi drmarcoguevara,
could you please share your code with us
Thanks
desanga is offline   Reply With Quote
Incompressible, miscible mixing of two fluid stream OpenFOAM Nishchal OpenFOAM Running, Solving & CFD 6 October 9, 2019 06:55
Which pressure OpenFOAM use for incompressible flow? P/rho or (P-101325)/rho ? panda60 OpenFOAM 16 August 14, 2018 04:57
Solving for two phase, incompressible, inviscid flow (OpenFOAM) Betsy OpenFOAM Running, Solving & CFD 6 July 16, 2012 05:58
Implementing a new LES Model in OpenFoam fs82 OpenFOAM 6 October 13, 2009 09:58
OpenFOAM - incompressible solver + porous zones Nicolai Heilskov FLUENT 1 October 23, 2008 08:34
