multiphaseInterFoam on unstructred mesh?
i set up a simple all hex test case which solved without problems. Now that i want to use multiphaseInterFoam with a more complex geometry which i generated with snappyhexmesh tough checkMesh runs just fine, the results are not satisfactory esp. the alpha values seem to be incorrect (>2 for three phases). Whats your experience with this solver, is i doomed to work only on pure hex meshes like twophaseEulerFoam? Would be interesting to now if someone solved non hexadral problems with multiphaseInterFoam!? Cheers |
