Getting inverted results on mass-fraction
Old   March 22, 2016, 07:58
Default Getting inverted results on mass-fraction
Abdiwe
Abdiwe is on a distinguished road
Hello everyone
I‘m modeling a flow inside cylindrical tube filled with the catalyst and this tube is exposed to a constant heat flux (100000 W/m2). The inlet gas is ammonia under around 600 K and 50 bar and when the gas go through the catalyst inside the tube it dissociate to nitrogen and hydrogen. The flow is turbulent, i calculate the viscosity resistance, inertial resistance, porosity and the surface to volume ratio (because i assume it’s wall surface reaction). My reaction is based on Arrhenius equation, so i thought i don’t need to write UDF function. When i applied all these conditions the reaction occur, however, the mass fraction result isn't correct. Based on the equation of my reaction 2NH3 ------ N2 + 3H2 which means the result of dissociated ammonia is very much 20 - 30 % N2 and 60 - 70 % H2 and about 10% NH3 (not dissociated). However, I'm getting exactly the opposite 60-70% N2 and 20 - 30% H2 and i don't know exactly why this is happening. Do you have any idea how can i solve this problem? Please help
Cheers
Abdiwe
[ Moderator note: This post was moved from here: http://www.cfd-online.com/Forums/ope...e-results.html ]
Abdiwe is offline   Reply With Quote
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
Species Mass fraction in Fluent prashantthaker208 FLUENT 5 September 30, 2020 00:30
gradient of species mass fraction zhou FLUENT 1 March 14, 2020 07:55
about Mass Fraction Jaloha CFX 0 June 16, 2008 12:42
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
