Boundary conditions on suction problem (simpleFoam) |
March 16, 2016, 05:10 |
thomas
Rep Power: 11 |
Hello all,
I am dealing with a 3D turbulent incompressible (air with M<0.3) suction problem case and I am quite confused regarding the correct boundary conditions I should be using, since I am not getting the expected flow. Solver: simpleFoam. I am still struggling with the p and U boundary conditions, so I havenīt implemented a turbulence model yet. I would be eventually using k-omega-SST with wall functions. My mesh has about y+ = 1, since I read that the k-omega-SST turbulence model with wall functions supports meshes with y+ < 30. The geometry has 2 inlets and one outlet, being one inlet an atmosphere-connected patch ("atm"). The other inlet ("inlet") has a constant volumetric flow rate. The outlet ("outlet") has a fixed pressure value (negative). So far I have used following boundary conditions for each patch: "inlet": U => flowRateInletVelocity p => zeroGradient / pressureInletVelocity "atm": U => zeroGradient / pressureDirectedInletVelocity p => fixedValue (0) "outlet": U => zeroGradient / pressureInletOutletVelocity p => fixedValue (-800) With these boundary conditions I am actually getting flow out of the "atm"-patch and it is supposed to be the opposite of that. Help would really be appreciated. Thank you very much in advance! Bye, Thomas |
Problem with Periodic Boundary Conditions Help!!! | otsigun | FLUENT | 0 | July 11, 2013 03:20 |
Boundary Conditions problem | o_mars_2010 | Main CFD Forum | 2 | July 8, 2013 02:10 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Problem with Boundary conditions | Mahiboobswamulu | Main CFD Forum | 10 | August 26, 2003 13:24 |
