reading timeseries into the solver-Problem with using dataEntry
Dear all,
I am trying to use dataEntry for reading text file timeseries into my solver. Following what is written in the code and looking into similar applications, I have managed to almost make it work... My only remaining problem, which I couldnt find a solution for, is: I have several variables which should be read from the text files, which I define them in constant/dataEntryProperties, as you see below. However, when there are more than one entry in my dataEntryProperties, it tends always to go and read the file in the last entry no matter what! I guess there is something wrong in the way I have written the dataEntryProperties, maybe missing some ";" or "(" somewhere? I woul be glad if someone can give me some hints on this, as I couldnt find any such examples anywhere else... /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dataEntryProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Qs_spill tableFile; tableFileCoeffs { dimensions [ 0 3 -1 0 0 0 0 ]; // optional dimensions fileName "Qs_spill"; // name of data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation method }; Xb_t tableFile; tableFileCoeffs { dimensions [ 0 1 0 0 0 0 0 ]; // optional dimensions fileName "x_coordinate.txt"; // name of data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation method }; U_timeseries tableFile; tableFileCoeffs { dimensions [ 0 1 -1 0 0 0 0 ]; // optional dimensions fileName "currentVectors.txt"; // name of data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation method }; Yb_t tableFile; tableFileCoeffs { dimensions [ 0 1 0 0 0 0 0 ]; // optional dimensions fileName "y_coordinate.txt"; // name of data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation method }; // ************************************************** *********************** // |
