Floating point exception crash at writeInterval
I am very new to OpenFOAM, so this initial post might miss some important information. But I will provide as much information as I can, if you could hint me in the right direction :-) My Problem is as follows: I have a quite simple cube-setup where I try to test a solver made by a colleague. This solver is basically a modified buoyantBoussinesqPimpleFoam. I have no Problems when running it with the cluster version of OpenFOAM(3.0.0). But as I had to do some changes I decided to compile my own OpenFOAM version from github (3.0.x). With this version my solver crashes with a Floating point exception exactly at the given writeInterval with the following error: Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? I can even do the run with the cluster-version until the first writeInterval and then continue from that point with the selfcompiled version. It then crashes at the next writeInterval. So I am not sure if the error above does say something to you (it sure doesn't help me very much...). But I would much appreciate if you could at least point me in some direction. And as I said, let me know what further information could help to understand that problem. Cheers, Matthias |
